I'm about to fit a set of ZX9R carbs to my red block, but would like to incorporate a manifold heater to prevent carb icing. I'd like the car to be reliable in winter months as it will probably be used for my commute sometimes.
First question, is this a big problem with bike carbs?
Second, in terms of method, I was going to weld a chamber across the runners with coolant outlets on either end, and run coolant through them. Would this provide sufficient heating?
1966 MK1 Cortina 1971 Hillman Super Imp 1985 Volvo 360 GLEi 1986 Volvo 340 1.7 1990 Mercedes 190e 2.0 1993 Peugeot 205 STDT
slater
Club RR Member Number: 78
Bike carb heated manifold?slater
@slater
Club Retro Rides Member 78
Can be an issue as the carbs are only joined to the head by rubber. Depends on the specifics of the car tho ofcourse
Don't go overboard. You will probably find just a bit of tube across all 4 runners welded where in makes contact would be enough. Plumb it in so you can isolate it during summe maybe?
Nice one, will go for that then. I think some ZX9R carbs might have heaters in the carbs already, so if there's potential to plumb those in, that might be better.
Tepper
I think some of them do have coolant passages, but I ran without any form of heating and never had any problems. Maybe give it a go and add it later if needed?
1989 Peugeot 205 GTi - stolen! 1983 Mazda RX7 1968 Rover P6 - also stolen.
fad
Nov 12, 2017 11:38:17 GMT
My Volksrod has engine oil flowing through a pipe on the manifold (goes through the turbo first). Its a draw through turbo system so the carb gets real cold. Silicone mounted, no issue with heat.
Nov 12, 2017 21:22:20 GMT
Zx9r from 1998 on had coolant heaters on them So you could just plumb them in
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
