Hi guys.
I have a Clarke strong arm, heavy duty crane. From the HDC range. Its a 200 if I'm correct. Max lifting 2 ton, minimum 500 kg.
The crane is huge and heavy, its dismantled down for easier movement. It will fit in a transit sized van, but you will need helpers to lift it as its a big sturdy piece of kit.
All bolts are there. Did lose the pin for the piston where it connected to the arm. But I've since replaced it.
I have had this to years and well its just to damn big for my use. But at the time it was all i could get.
Ideal for big heavy ass engines. Could even lift a car up
Collection only on this. Due to the size and weight.
All I'm asking is £60 please
This is a picture of what it looks like assembled
And this a picture from Clarke's website of the one this is
