gumpy
Dec 30, 2017 17:24:17 GMT
Last Edit: Jul 22, 2018 16:50:50 GMT by gumpy
Dec 30, 2017 18:54:49 GMT
Nice project. Love a weldathon especially on an a Cortina. I welded my mk2 for 2 years. Mk1 owners club does a lot of the usual suspect panels. Keep us updated.
Dec 30, 2017 21:27:22 GMT
Nice find! It's good to see another mk1 on here, it looks like it has some good bits on it
gumpy
Dec 30, 2017 21:39:19 GMT
Nice find! It's good to see another mk1 on here, it looks like it has some good bits on it Yeh I couldn't let this go, it's likely it would've gone to somebody who would've broke it for parts. Yeh the 1500 xflow is a nice touch I checked today it's still on its standard bore size including the original 4 branch manifold and weber carb so I imagine it's worth a few quid. *edit I've been following your cortina thread really good work on the bodywork !
Last Edit: Dec 30, 2017 21:41:42 GMT by gumpy
Very nice find, I will be following your build as I have a 64 pre-airflow that I am slowly rebuilding. Cheers Warren
gumpy
Dec 31, 2017 11:02:06 GMT
Nice new beige leather steering wheel! You´re a man who knows how to set priorities! Adds instant mojo to the build 😉
Dec 31, 2017 15:24:48 GMT
Thanks enduring my rammel!
Standard bore is rare! Mine has had 2! The selector is worth a few ££ too. I like the mx5 idea I've seen one in a mk2 so this will be special
gumpy
Dec 31, 2017 21:19:01 GMT
Thanks enduring my rammel! Standard bore is rare! Mine has had 2! The selector is worth a few ££ too. I like the mx5 idea I've seen one in a mk2 so this will be special Any build thread on the mk2? I have 2 of these selectors heard they fetch a bit. I enjoyed the thread dude hopefully I can have my floors looking as good as yours haha
gumpy
That's mine , it's off the road as it munches through clutches due to a knackered crank taper. I'll be doing a mid engine conversion on that one day.
gumpy
Adds instant mojo to the build 😉 Bet you´re hoping for a self cure effect?! When Arnie Cunningham started his TLC programme with a new pair of wiper blades, Christine took care of the rest soon... If the magic welder fairies could make an appearance whilst I'm at work that would be terrific. 😂
gumpy
Jul 22, 2018 15:08:10 GMT
It's been a while since an update, with organising my wedding and a new job I've had little time(and money) to really go full speed on the Tina build. But I've managed to chip away slowly. So I acquired a race prepped 1.6 mx5 engine from my previous workplace aswell as some Cusco zero skyline coilovers rescued from the scrap bin !(any slight damage to parts often got replaced). The engine is in very good condition, ported head etc also very similar looking to the lotus twin cam so I paid homage to the cam cover And 3d printed the lotus emblem's and set in place with resin. I have an Arduino based ECU built up called speeduino and painstakingly stripped an entire mx5 loom down to just engine sensors and fuse box, the engine will be running a set of motorcycle throttle bodies once mapped should be a nice revving powerplant that's not overly powerful and reliable as I want to use the cortina most days. Although the engine pretty much fits on the standard xflow mounts it's a tall engine and bonnet closing would be impossible. So likely I will chassis mount it although I want to keep the steering box setup so will have to do more measuring. Those gtr Cusco coilovers are fully adjustable and the best bit is they were a perfect fit to the cortina stub axles. Once welded they were given a coat of zinc primer and satin black. The body has been partially stripped back to bare steel and alot of rust found what needs replacing are floors , boot floor , fuel tank , both rear arches , outer sills , some patches in the engine bay and some patches on the roof. Luckily I work for a restoration shop and have access to metal working equipment , I started making the floors and hopefully in a few weeks can start on cutting the rust out and replacing. .
Jul 22, 2018 15:51:04 GMT
That's a proper barn find. None of this "just rolled off the line, the barn is air conditioned and carpeted, honest" malarkey. Love it.
Jul 22, 2018 16:18:51 GMT
That's some work ahead but certainly different. 4 doors, MX5 unit. This is going to be interesting, looking forward to updates. Bookmarked.
1980 Vauxhall Cavalier MK1 1970 Mobyleete 40T custom 1978 Mobylette 50V 1965 Moulton Standard 1979 Raleigh Grifter custom 1980 Raleigh Grifter 1982 Raleigh Grifter BMX custom 1982 Raleigh Bomber 1987 Strida
Jul 22, 2018 16:34:49 GMT
You just made me smile.
In fact, grin madly.
Busy doing woodwork as I looked at my trucks fenders earlier today and decided woodwork was an easier option.
Thanks for the update.
I hope you get the time and cash you need to get this job done.
gumpy
Jul 22, 2018 16:44:58 GMT
You just made me smile. In fact, grin madly. Busy doing woodwork as I looked at my trucks fenders earlier today and decided woodwork was an easier option. Thanks for the update. I hope you get the time and cash you need to get this job done. Thanks grizz, I'm hoping my boss will allow me to store it at the shop for a few weeks which will allow me and the fabricator to pull some late nights getting it solid and hole free. There's nothing more frustrating than making measurements of things making them at work getting home and finding out it doesn't fit. Woodwork.... I'll take rust and metal over wood haha
gumpy
Had a few hours spare today so started chopping the floors out, fair bit of rust in the box sections so will likely cut out and replace.also test fitted the floor panel I made. Still haven't got around to getting gas for the welder yet. Looks like I'm going to have to lose the heater box and put a big tunnel In as playing with engine fitment I've got a few options, A. Try and source a front bowl sump from an mx3 (rare) and modify the oil pickup and dipstick B. Convert to rack and pinion , expensive and I'd really like to keep the steering box setup. C. Cut the bulkhead and fabricate a large tunnel and lose the heater box , I'm going to go with this idea as it leaves me space for the radiator without any cutting up front. if anybody has ideas for a space saving heater and blower setup I'm all ears. Hopefully this doesn't put the gear lever far back out of reach I'll cross that bridge when I get to it. My boss has agreed a date in January where I can bring it in and get the metal work all done so for now I'll concentrate on the engine fitting and mechanical bits.
I think I'd be changing the sump to a front bowl if it was mine. Moving the engine back gives to many knock-on problems. Like you say gear stick, no heater, possible pedal problems. With the sump change it's just that and the pick up pipe. Ok even if it's an alloy sump and you have to pay someone £50 to weld it back up, it's hell of a lot less work. You might get away with cutting the sump flange off, spinning it around and welding back on.
gumpy
I agree jonsey, it's only now I've sat and thought about it that even with a front bowl sump the bonnet still wouldn't close. These Mazda engines are pretty tall! And factor in that the bell housing bolts up to the sump I think modifying it would be a hefty task. Other than scrapping the Mazda engine idea I'm sure I'm gonna have to cut the bulkhead, albeit only slightly there's no pedal interference only losing the heater box which is a big ol' unit.
I agree jonsey , it's only now I've sat and thought about it that even with a front bowl sump the bonnet still wouldn't close. These Mazda engines are pretty tall! And factor in that the bell housing bolts up to the sump I think modifying it would be a hefty task. Other than scrapping the Mazda engine idea I'm sure I'm gonna have to cut the bulkhead, albeit only slightly there's no pedal interference only losing the heater box which is a big ol' unit. Before you do anything, take the sump of the engine. Sit it on a bit of wood on the crossmember at the lowest point you think you will get away with and the refit the bonnet. I reckon there will be heaps of room. I doubt there is much difference in height compared to a zetec and there were a good few at Stratford Race course today. They even have them in mk1's with pretend Lotus rocker covers that are huge and sit over the cam pulleys effectively make the front of the engine really tall. The front of an mx5 isn't tall looking side on. Try it first Here's one in a mk2. It's tall and fits in a mk1
Last Edit: Aug 5, 2018 18:52:27 GMT by jonsey
