In the bid to clear my storage areas and free up workshop space I need the following to go - happy to help post wise but some of it is a bit on the heavy / bulky side so it would be better collected anytime to suit yourselves or organise yourself a courier - I am mid point between Reading / Newbury / Basingstoke - just send me a pm if you need further info / help
1: Warco Formit 300mm - 3 in 1 sheet metal machine - rolls, folds & shears - good for making up repair sections - especially multiple folds, curved panels etc - full spec below from the supplier - It's had very, very little use from new - full working order (I need a much larger folder for my work now) - Bargain @ £100 (£225 new from Warco or £300 + for the identical model from Clarke) - Its a heavy 46kg so better collected unless you can find a courier that will collect it - happy to box it up etc at my end
www.warco.co.uk/sheet-metal-fabrication-machinery-metalwork/93-formit-universal-sheet-metal-machine-roll-bending-shear.html
See pics
PROVISIONALLY SOLD - PENDING COLLECTION
2: Door grab handles - new ideal for camper / van conversion etc - £6 for the pair
3: Badger Airbrush - model 200-3 - New / unused / complete kit / original box & instructions - £25 (£80+ on e bay) - SOLD
4: Airbrush - suction feed + 3 cans of propellant / hose / instructions - £15
5: Powertool cases - closing catches & carry handles - ideal for workshop / garage storage of your kit - Dewalt 500mm x 300mm x 130mm - interior moulding removable - Sentinal 300mm x 300mm x 100mm - moulded interior - £5 the pair
6: JCB-05 Electric orbital sander - 240 volt / 250 watt - with dust bag & instructions in slightly battered box - base plate / sanding area 180mm x 90mm - in good working condition and would be fine for getting to grips with areas of filler - £10
7: Black & Decker - Sander (Mouse) 240 volt / 55 watt in original case with various sanding pads - good working condition - fine for sanding the awkward areas that the circular disc type machines can't access - £15
8: Borehole pump - Great for getting the waterlogged vehicle inspection pit emptied - professional quality - 25mm outlet - complete approx 13 metre reinforced outlet hose & circa 20 metre cable - 240 volt with switched control box - 125mm diameter x 500mm in height - good working order - fed up of falling over it - hence bargain at £40
9: VW Type 2 - Windscreen aperture repair sections - new - supplied by Just Kampers (Their part number - J12238) £15 (JK price is £34.75)
See pics
