I've decided to write this since recently the times have changed but also if I had a £ for every time a starting query came up with batteries being involved and seeing information about 'that should be OK' I'd be a rich man! Let's put it like this. I'll give my take in a few chunks/posts and then you can give your experience OK? Let me know if I go on a bit, I I’ll be honest. If someone offers you something that looks like it will save you cash in the long run I am the first there. However, as time goes on I have become more cynical about a number of the products. With batteries however, I used to normally change them after a good few years In most cases this is the right thing to do. But with products like the above and batteries getting pricier you do soon start to look to other avenues and old myths like leaving a battery on charge forever. One such product has been the CTEK smartchargers. Reading the stuff around them you’d think they could revive a battery from the dead and let you know if a battery is usable or not or at least a number of owners do. But can they? Over the hundred and thousands of miles I have covered in a number of cars under a variety of disciplines you pick up a few things, look back for answers and sometimes even change your existing answers due to outcomes. So here is my experience about car batteries and devices out there. I’ve drawn these conclusions from experience, and recently trying out my CTEK MXS-10 charger and other chargers on a few batteries and also having a further means of testing ; a conductance meter, one which I have checked against a few other meters. It's confirmed a few things that I thought anyway. The Nitty Gritty : Battery Testing/HealthI have 12.5V but I cannot start my car. Surely that’s a problem elsewhere like a starter or a cableNot so fast! I’m sure a few of us have been here. I know I have! However, remember the power equation? Power = Current x Voltage Also shown as P=IV Where P = Power, I=Current & V = Voltage. That means voltage alone won’t start your car, you also need current. Having a fully charged battery won’t mean that you have the stated current on the case either. Of course, that latter figure is influenced by a number of things including. • The type of battery • The depth of discharge the battery has received • The age of the battery So how can I check the Current?Unfortunately it’s not as easy as putting on an ammeter. On a multimeter type you’ll blow the fuse in the meter. On a larger type you may well cause yourself an injury! But there are two other ways you can check, including: • A Drop-Tester • A conductance tester • The Multimeter Let’s firstly get the multimeter out of the way. It will let you know if the battery is charged. But if a battery is goosed? Only in a few cases, like for instance if a cell has gone bad or if the battery is completely shot. I know I have been caught out here as others. But don’t despair. There are more battery specific testers out there however. The Drop-Tester is good and it is also cheap at around £20 but it needs a fully charged battery in order to get a reliable reading ; after all, power is influenced by voltage as said previously. Having the resistance value of the tester will help here. For this reason, most of the cheaper drop testers have a card to use so as to correlate the data of your battery against the tester. The second and newer type of tester is a conductance tester. This uses data given by yourself in addition to checking the internal resistance of the battery so as to give the outcome of the battery. These give a good amount of information and are now available for as little as £40 for the home mechanic up £1000s for someone who tests batteries day in and day out, like a motor factor. The conductance tester gives valuable information too including: -State of Charge (SOC) given as %. How much is the battery charged? -State of Health (SOH) given as a %. How healthy is the battery. Can it perform at maximum capacity? -Actual CCA or similar rating : How many amps does the battery produce This will visually show you how the battery is. The tester will also let you know what it believes you should do from recharging the battery to replacing it. Even on new batteries this can give surprising results. I’ve seen new batteries fail the test completely, irrelevant of if they have been thrown into the car from the off or recharged. That concludes the testing side. But what about the batteries? Can chargers really bring batteries back from the dead?
Last Edit: Jan 4, 2018 17:27:51 GMT by ChasR
turbom
Good info there I worked with a guy who always charged his car battery in early October and again early april for a full 8 hours his battery lasted years. And that was on a Toyota cresida diesel and he only travelled 3 miles to work every day through town.
Good info there I worked with a guy who always charged his car battery in early October and again early april for a full 8 hours his battery lasted years. And that was on a Toyota cresida diesel and he only travelled 3 miles to work every day through town. Cheers! It seems pretty obvious but then most things are with a bit of thought . The guy is on the right lines more than he thinks believe it or not. But now for a little about keeping the batteries good and what kills them. But what about the batteries? Can chargers really bring batteries back from the dead?Yes & No. Mostly the latter. With the batteries it is a case of how it has lived as previously mentioned. But with care batteries can last. My M3 amazingly is on its original battery and I know of a few cars that are as is a spare BMW battery I acquired. It’s 6 years old and is still in perfect health as a spare battery from almost day 1. A friend’s 2001 Focus is also on the original, but now dying battery. Have we been lucky? Not quite, as I shall go on to explain. What tends to kill batteries is sulphation of the plates. That arises from two main causes • Excessive Discharge Cycles • Neglect This is one reason why Taxis and commercial vehicles tend to have a limited warranty ; their batteries are constantly started and stopped and taking a hammering. As for neglect this is probably the biggest killer to most of us here, with some batteries taking it worse than others. Stop/Start batteries attempt to circumvent this by using AGM batteries but that is a discussion for another time. When I say neglect I am referring to the batteries being discharged excessively. This could be from the car being stored and left, the car being left a while and only used on shortish trips, or it never receiving a true saturated charge if say the vehicle was flattened by accident. Of course, battery drains can contribute towards this. Some batteries don’t take this as well. IME Gel batteries don’t and even some AGM/AGM based batteries don’t seem to recover well once they have been flattened excessively and then left without a proper recharge. Once sulphation has started it needs to be caught. Not catching it in time will allow it crystallise which is what kills the batteries. Of course, the solution is to ensure the battery is kept fully charged or as close as possible to on vehicles that do short trips or aren’t used much It’s OK. I’ll drive the car down the motorway. That will charge it right?Not quite. Driving the car down a motorway for a while doesn’t recover a battery fully. This is because the alternator doesn’t always have the chance to and with more consumers in a car it can’t really. What it will do is give a surface charge to the battery and give the illusion of it being charged for a short while. Lead acid batteries respond better to a slower charge Surely that doesn’t matter? My fancy CTEK or similar charger can solve anything.Erm, no. A CTEK or other smart chargers cannot remove permanent sulphation. Once the damage is done, it’s done. It even says that in the depth of the CTEK FAQs and the manual. What a smartcharger can do is keep whatever capacity your battery has left good, and prolong the life of that capacity; the error phases won’t say if the battery is any good, merely that it will accept a charge and/or to a semi-usable capacity of the battery. It can ‘bring back’ a small amount of capacity IME thanks to its fancy multi-stage process which can do a better job than an el-cheapo charger. A pulse or other type of automatic charger will tend to give you most of the things the CTEKs can and charge a battery up almost as well, so you’re not losing out much to not having a smart-charger. As in to within 5% off a CTEK or another smartcharger can. A smartcharger can maintain a battery better admittedly I must admit and is safe in that respect. I’ve probably missed something but that is about it. So what can I take away from this?A bit hopefully • Always ensure the capacity of your battery is adequate for your car. Using the stock figures for your car helps here or similar. • A multimeter will essentially show if your battery is completely shot. Not whether it is usable for your application. As said, I’ve had poor cranking situations with a 12.6V float on the battery. With other testers now being available cheaply it may be worth considering one if you have quite a few cars. • Leaving batteries in a car unattended and unused is what can kill them. Also not correctly recharging a battery once the car has gone flat after say a bad alternator or leaving the lights on does not help. • Having a semi-smart or smart charger can indeedy be beneficial, but it will not perform miracles. If you want that, watch a movie with them in. It seems pretty obvious but then most things are . As said I've managed to come to my conclusions from what I've experienced and seen others experience. However, I've done some reading and helped that aid my conclusions. One helpful site is this one below: batteryuniversity.com
Last Edit: Jan 5, 2018 8:19:04 GMT by ChasR
A very small thing that can cause so much ballache. I tend to follow the same thing as my day job, and replace 4-5 years. I also keep on a smart charger if not used and i have a decent tester to test the capacity.
Chas, what perfect timing. Up until recently, the '38 was used at least once a day during the week for the school run and sometimes more, but mainly all short distance, even if sometimes long in duration! This kept the battery in a good enough state to easily start the vehicle, but probably never properly charged it. Now she's been promoted to weekend toy only, the battery probably needs a bit more consideration and, when left unattended the first week flattened over the inactive five days. Hence me suspecting it's not fully charged. Last weekend, I stuck it on charge Friday evening and left it, on the 2A setting, overnight and Saturday morning, after which it showed >75% charged. Ran it out on Sunday then fired her up again on Wednesday until hot. All being well, I'll take her for a run on Saturday or Sunday, but again, probably not far enough to "fully" charge it.. Obviously there'll be some weekends when other things are happening, so it could sometimes be two weeks between runs. As my charger is able to tell me about various states of charge I assume it to be at least semi-literate, if not actually intelligent. So my question is this... If I want to keep the battery in top condition, what's the best course of action? Just leave the charger on it? Hook it up on a Friday? Do nothing; suck it and see? The ambient heat kills them pretty quickly anyway, so anything I can do to prolong the battery life is a bonus! Thanks!
There's always one who asks the awkward questions georgeb . Honestly, if the charger is smart (this would need to be verified first I'd be tempted to put it onto charger every month or so. While it probably would be fine left on charge long term and I know of many who have there is a complication you potentially have over the UK. Heat. Unfortunately that will finish off a battery faster as you are aware, but it will roughly be around half of how long a battery lasts over here. Do you know what charger you have? The Ring items are semi-smart.
Don't mean to be difficult, honest, ChasR I was getting around three years in Malaysia, but doing a lot of longer trips at speed, and around two years here. This one's probably due for replacement anyway as it's been over two years now, so I may do that, then set up a regime of regular charging over and above the weekend runs. I'll see what make the charger is when I get home, but I'll bet it's not very bright! Useful thread!
Last Edit: Jan 5, 2018 10:48:26 GMT by georgeb
I was kidding about the awkward part. It's nice to consider different scenarios .
Actually, given that a new battery is only a phone call and twenty minutes away, I'm going to see how long I can make this one stretch.
It was fine this weekend, so I'm going to try it with a charge every four weeks or so.
Good timing as said (my daily isn't getting as much use as it normally does..,), the battery was near flat last time I tried to start it. Removing the battery and putting it on the charger (Optimate4 intelligent charger) took more than a day before it showed as fully charged. The charger will overcharge (18 volt / 24 volt ?) to kick-start dead batteries, not a good situation to be in but it has brought back a couple of batteries that were scrap. When I had a spare battery, I tried to swap it with the one on the car every few months just so they both got plenty of "excercise". It seemed to work. Any advice about using a solar battery charger (sat on dash, plugged into cigarette lighter etc) for a car that's parked up for a while?
Good timing as said (my daily isn't getting as much use as it normally does..,), the battery was near flat last time I tried to start it. Removing the battery and putting it on the charger (Optimate4 intelligent charger) took more than a day before it showed as fully charged. The charger will overcharge (18 volt / 24 volt ?) to kick-start dead batteries, not a good situation to be in but it has brought back a couple of batteries that were scrap. When I had a spare battery, I tried to swap it with the one on the car every few months just so they both got plenty of "excercise". It seemed to work. Any advice about using a solar battery charger (sat on dash, plugged into cigarette lighter etc) for a car that's parked up for a while? With an Optimate 4 you can leave it in the car, as long and you don't use the recondition mode or the 18V one which may be the same thing. Given the modules etc. modern cars have I'd be tempted to leave the battery in . IIRC those have a CAN-BUS mode which is handy for this. Going to 16V is good but it's not something I'd use on a battery often unless it is fully flat ; it's great for getting more life out of a battery since it allows for the acid/water to be remixed and stratified but it can cause water loss due to how it does it, even if it is controlled; it affectively separates to the water into oxygen and hydrogen with controlled boling(ish) so that the mixture can become useful again. CTEK themselves say not to use the mode much (1 a year on a good battery) unless it is fully flattened). With your E90 you have an additional problem. You may well have the Intelligent Battery System, aka. IBS (don't go sniggering now!). If you swap out the battery it's advised to get the new battery, preferably a new one, coded to the car. BMW do this and the iCarly app with the right OBD bit can do this, albeit at £100 but it can diagnose and code your car too and much more. Failure to not code the new battery can play havoc on the battery life. Basically, BMW made the IBS so that it could vary the charge rate to the battery as it got older and to help a little more with the emissions in general. The solar chargers seem to be a mixed blessing. I know of a number of people who have binned them, but the odd person who has sworn by one, but you are talking over a week in terms of letting it charge for those few rare cases!
Last Edit: Jan 8, 2018 9:18:30 GMT by ChasR
If georgeb isn't going to be awkward, I will! Can you tell me, scientifically like, why winter, and particularly the frosty period like we're having now, always wreaks havoc with my batteries? Regularly year on year we'll have about 50% of our car batteries die of frostbite. This year so far it's taken out both vans and three or four cars - so far. I would also recommend the Sealey BT-2101 to anyone in need of such a device. A comprehensive diagnosis and ultimately very accurate. However like any good diagnostics system that will point you in the right direction, not replace the function of a working human brain. Anecdotally, we once rescued a battery which had flat-lined and had 3.3V showing, but 48 or so hours on a very slow charge (using a large capacity Maybole device I'm very happy with) and it came back into being. That's one of several dozen, maybe 100, that have not been revived though. 9v seems to be the limit, anything below that and it's too far gone. I'm guessing that's because more than 3v gone means a cell is dead..?
The cold one is relatively simple to explain and it is one that is influenced by a few factors. But batteries can be a little like humans when things get cold . 1) Batteries discharge more when they are cold. This is one of the reasons why its is recommended to store batteries cold, as with the higher discharging they are more suspectible to sulphation. 2) The cold temperatures reduce the effective CCA of a battery which doesn't help. Conversely hotter temps can increase the battery CCA, to a point 3) Batteries which are discharged are more susceptible to freeze. A fully charged battery can go down to -50 degrees Centrigrade. A fully flat one? -5. That is down to the chemistry of a battery and what the electrolyte becomes when flattening (sulphation) takes place. It is said cheaper batteries don't have as good an acid mix for the electrolyte which seems to be more common these days unfortunately, as one ex-battery manufacturer bloke said here. As I said earlier, a car will generally only give the battery a surface charge, especially when the battery has flattened, rather than actually fully charging the battery up. Of course, a frozen battery can cause further damage to a battery. 4) Battery size. I know of tons of people who fit a lighter battery to save weight and say "12V is 12V right?" yet forget power is derived also from current In a semi-discharged state thanks to the cold and probably never seeing a charger this will affect things even more. Like most things, do people really think the manufacturers whacked in a big battery just because they could? What I'm basically saying is keep the batteries charged during winter if they are going flat or the very least ensure they are fully charged at the start of winter and at the very least match the battery that the manufacturer supplied with the car ; I know Halfords suggests a smaller battery for my dad's car than what Ford supplied it with ; Ford changed the battery spec it seems depending on the spec of the car. I'm sure they do the same for my M3 ; most of their batteries don't match the Ah rating of my battery, which is the original dealer battery going by the date stamps. We use that Sealey tester at work, and it's not far off a fancy Midtronics tester. Again, they are a guide but not conclusive as you say . Nowt wrong with a Maypole charger either ;they were one of the first people on the scene.
Last Edit: Jan 9, 2018 8:40:57 GMT by ChasR
Thanks so much for this, there's so much misinformation out there on batteries!
Current fleet 2022 VW E Up! | 1991 Bentley Turbo R | 1998 Nissan Elgrand 'Highway Star' | 2003 Mazda MX5 1.6 (for the purists)
taurus
The battery in my current (no pun intended) daily is now 19 years old so I reckon I’ve nearly had my money’s worth out of it.
A few things I’ve learnt over the years....
My CTEK charger is great for topping up batteries but I don’t leave it on maintenance charge for too long. Better to connect it up either overnight once a month or for 30 minutes a day.
A handy bit of kit for resurrecting very flat batteries is a 400Ma gell cell charger. Cheap as chips and great for priming batteries that show very low voltage.
Batteries contain magic imps that obey no laws of physics or chemistry. They can work fine at 8.00am and then all escape by 9.00am. They will usually time their escape to coincide with the most inconvenient moment.
jamesd1972
Club RR Member Number: 40
Jan 18, 2018 17:25:39 GMT
Quick point on cold failure I'm sure I'm pointing out the patently obvious to everyone but in the winter isn't the issue more about cold engine needing more power to get it to turn over - thicker oil etc. so a tired battery cries enough at this point ?
Also why if you have a self caused flat, from leaving the lights on for example, if you turn them off and wait a few mins you have more chance of starting than trying straight away ? Never understood it but has worked for me (kids and interior lights ...)
Thanks for the thread
Jan 18, 2018 19:34:55 GMT
As far as fitting a big battery to improve functionality goes while a good idea this is just not possible in many modern cars as the battery cradle is too small. When I say modern I'm referring in particular to my wife's 1990 Ford BG Laser. The battery cradle in that thing is tiny. I recently (last winter maybe) replaced the battery in that just to be sure it would start for her every time. The battery I removed (now five years old) is still a good spare that I would use in my own car if necessary but I don't need the bs I'd get if her car wouldn't start even just once. As to winter killing batteries I have always believed that at least part of the issue is the higher usage of electrical things in winter, in particular lights and wipers. In summer a dodgy battery may be fine as it is only required for starting and gets a chance to at least half pie recharge while driving. In winter, with lights on constantly when driving, this doesn't happen. This seasonal variation will be even worse for you folk in the UK cos you're further north than I am south.
Jan 19, 2018 13:17:41 GMT
Quick point on cold failure I'm sure I'm pointing out the patently obvious to everyone but in the winter isn't the issue more about cold engine needing more power to get it to turn over - thicker oil etc. so a tired battery cries enough at this point ? Also why if you have a self caused flat, from leaving the lights on for example, if you turn them off and wait a few mins you have more chance of starting than trying straight away ? Never understood it but has worked for me (kids and interior lights ...) Thanks for the thread Pretty much what you have said as well as igor. Couple with batteries not being as effective in colder climates, especially when discharged doesn't help matters. Your last point is down to the Hydrogen condensing as the battery isn't used, thus making the electrolyte more effective, thus making the chemical reaction more effective. There is a little more to it that that There are some pretty graphs to illustrate this on the web .
steveg
I'm looking for a decent charger to sort out a few of my car batteries. My main need is to have something to top them up so I have been looking at the Ctek MXS 5.0, the Noco g3500 and a GYS FLASH 6.12. There are various reviwews on the Ctek and Noco but I can't find much out about the GYS one.
Can anyone offer any info about them ?
From the looks of it that looks like a smart charger and should be OK. Is there a reason why you fancy the GYS over the CTEK/Noco? The CTEK is around the same money and have a variety of handy accessories like the comfort connector, handy if you want to put the charger on with minimal fuss onto the car. I have a comfort connector on my M3 which makes charging it handy in storage and a friend has an SAE to Comfort converter on his for charging his motorbikes up over winter . Lidl have some smart chargers for sale for £12. These are allegedly cloned old generation CTEK MXS 3.6 chargers but I cannot confirm this.
Last Edit: Feb 6, 2018 13:56:56 GMT by ChasR
