kee
Sept 13, 2007 11:27:04 GMT
if you don't know the power and weight, search carfolio in google, and then search for your car, its likely to be there, unless you have a strange car. rules post a pic of the car actual BHP BHP/Tonne I.e. mine is 69.0 bhp 89.03 bhp/ton
Last Edit: Sept 16, 2007 16:54:02 GMT by kee
Sept 13, 2007 11:37:48 GMT
Are we talking calculated fudged flywheel or wheel power? and we talking actual RR figures or manufacturers stated 20-50 years ago? Last RR sesh Fly 195 bhp 150 / ton Cant remember rwhp
Sept 13, 2007 11:38:06 GMT
Mine: Somewhere like 45hp now so 50hp/tonne? ;D
Sept 13, 2007 11:40:30 GMT
270ish BHP (engine) 1100kg So 245 per ton. But that's not RWHP. Able car. Not able driver! Edit: according to www.carfolio.com/specifications/models/car/?car=30426&Ford the original car has a power to weight ratio of 163/ton. Maybe I'm being over confident. 200/ton. Better breathing, fat exhaust, no cat, bigger injectors, custom chip, major weight reduction (until I get in that is) Original car could do a quarter mile in 14.4. Charlie
Last Edit: Sept 13, 2007 11:52:12 GMT by charlie
Sept 13, 2007 11:46:09 GMT
Carfolio says: 60 BHP (@5550 RPM) 86.33 BHP/Tonne Engine is 82,000 miles old and has a couple of mild 'go faster' bits so prob putting out about stock power.
Sept 13, 2007 12:01:40 GMT
Carfolio only shows the 55A 1.1 Yugo...
56.0 bhp
69.83 bhp/ton
I'm guessing that although mine is the 903cc, I've stripped a lot of weight out, so it maybe balanced the BHP/ton figure?
Last Edit: Sept 13, 2007 12:05:50 GMT by jettadeluxe
bstardchild
Club RR Member Number: 71
Sept 13, 2007 12:08:54 GMT
Flywheel or Driven wheel bhp
Metric or imperial Tonne
Monza 1400 kgs (plus 75kgs for driver after all it's not radio controlled is it!) 235 bhp (flywheel) ~190 bhp rear wheels
Pretty poor but it's a heavy car!!
Sept 13, 2007 12:10:03 GMT
NOT ENOUGH.
pbottomley
If at first you don't succeed, then skydiving isnt for you
Sept 13, 2007 12:13:04 GMT
HA 44bhp..
Car 715 KG Driver 120 kg (yea fat knackker)
equalls a paint rippling 52bhp per tonne...
Sept 13, 2007 12:26:13 GMT
39bhp - book figure as I haven't had it on a rolling road. Kerb weight - again book figure - 715.3kg That makes... wait for it... over 54.5 bhp/tonne maybe I should take up drifting ;D Graham
Sept 13, 2007 12:31:46 GMT
90bhp 700kgs 130bhp/tonne 45bhp 800kgs 56bhp/tonne Eventually..... 130bhp 450kgs 290bhp/tonne. A variaty
Sept 13, 2007 12:32:46 GMT
About 115bhp (guestimate off factory figures - probably more though given the tweaks) About 1250Kg (weight fluctuates depending on how much rust I've just dug out & whether it has been replaced yet with fresh steel)
So just 92bhp per ton. However also has a torque curve like Table Mountain ;D
Sept 13, 2007 12:35:45 GMT
My RV jeep is about 200bhp per ton, and the cortina should be aout 220 per ton when its finished
Sept 13, 2007 12:40:20 GMT
Stripped out `79 Kadett 800kg Supercharged 1600 sigma - 220hp (going on the calcs and also the Cooper JCW makes 220 from 1600cc with a far worse head design) 275bhp/ton ;D
Last Edit: Sept 13, 2007 12:45:27 GMT by CR500Dom
Sept 13, 2007 12:46:21 GMT
The Spanglebox: 145hp x 750Kg = 190hp/tonne I forget I have that car sometimes
Sept 13, 2007 12:56:57 GMT
The Spanglebox: 145hp x 750Kg = 190hp/tonne I forget I have that car sometimes I bet thats fun !!! ;D
tofufi
South West
Sept 13, 2007 13:03:21 GMT
Beetle : Power : 44BHP (book figure) weight 725kg (book figure minus guesstimated carpet weight ) = 61 BHP/tonne.
Sept 13, 2007 13:06:48 GMT
Approx 98 BHP/ton The engine should have 115 bhp, but its done 103k so I am probably down on power even with the 4-2-1 manifold and exhaust NEED MORE POWER STAT
Sept 13, 2007 13:09:07 GMT
140bhp 880kg 160bhp/tonne
1988 Peugeot 205 1.9 GTI - Retro daily/trackday/weekend car. 1991 Peugeot 205 1.4 XS fixer-upper. Needs TLC and MOT. 2000 Vauxhall Corsa 1.2 16v - Commuter-mobile. Tiny share of: 1979 Austin Allegro track car project. Bright orange 2 door. Oh yes. Soon: 1990 Nissan Bluebird 1.8 with all the toys Even Sooner: Trackday car. Something fast with RWD please!
sav
Sept 13, 2007 13:13:02 GMT
46 BHP 64.34 BHP/Tonne ;D Wolseley 16/60 61 BHP 54.46BHP/Tonne | | | | | | | | | | | VVVVVVVVVVVVVV
