I've got the narrowed RX8 rear suspension fitted to an MGB and next job is sorting some spring and dampers. Rather inconveniently there is a chassis in the way of running some coil overs in the stock place but I could fit a bit of tube through so I'm thinking push rods to inboard coil overs.
If I build it so the movement is as straight as possible on the coil overs is there much else to consider in alignment? I've kept the standard RX8 geometry/arms/hubs, does the angle of push rods, rockers and coilovers have much effect?
Thanks!
Thanks!
