Mar 18, 2018 11:13:53 GMT
14-01-2018 i stripped the inlet down today as I'm going to take it to the engine shop to go into the hot wash with the sump and cylinder head, I'm glad i decided to do this as the inlet is really filthy inside so wont do it any harm to be cleaned. i have also discussed getting my flywheel lightened by them which ill be going ahead with orderedn following parts complete head gasket set with oe spec payen gasket victor reinz head bolts complete bottom end gasket set cam belt/tensioner and water pump high pressure oil pump ARP con rod bolts i have also bought a full engine nuts/bolts/studs/washers etc set from retro bolts so we know we will have fresh stuff and nothing missing or incorrect.
Mar 18, 2018 11:14:40 GMT
Mar 18, 2018 11:15:37 GMT
24-01-2018 been keeping the postman busy lately haha gates cam belt/ina tensioner and water pump victor reinz head bolts billet crank pulley weighs 340g compared to oe 620g stack mechanical boost gauge stack mechanical oil pressure gauge newman cams timing disc so we can get things absolutely spot on with there cvh turbo cam. a few more pieces to the puzzle as you can see
Mar 18, 2018 11:16:40 GMT
28-01-2018 finally got the crank and last related bits removed from the bottom end. It will now 100% all be going to the engine shop for inspection this coming saturday, we had a good look at crank and bearings thrusts etc look good so hopefully we get good news from it.
Mar 18, 2018 11:18:55 GMT
30-01-2018 got a nice update from the engine shop earlier today the block only requires re honing crank just needs polishing so iv now got new mains/big ends and thrusts on order along with a set of +0.5mm piston rings. Once they arrive there wont be much from stopping us building the whole engine up 02-02-2018 had a few more deliveries and also got the bottom end back from engine shop mahle +0.5mm piston rings mahle crankshaft bearings pistons/rods all cleaned up and rings removed crankshaft polished block hot washed, and bores plateau honed and a marmite mod motorsport developments dump valve. please don't worry i wont be butchering any boost hoses as i have a roose hose with the dv part on there. we are looking at starting the engine build next sunday
Mar 18, 2018 11:20:33 GMT
05-02-2018 engine stand is now in the conservatory ready to bolt the block up tonight and get cracking this sunday, I'm going to paint the block one evening this week also. (yes that is my son on the pic behind being foreman haha) block bolted up to the stand and 2x coats of engine block enamel applied, iv also degreased quite a few parts ready for sunday. couple more bits arrived today ARP Rod bolts oil pressure switch as far as I'm aware they were the last bits i was waiting on
Mar 18, 2018 11:22:03 GMT
12-02-2018 Had a really productive day building the engine yesterday, gotta say a huge thanks to my good mate karl for giving up alot of his sunday to come and help out. as you will see from the pics, crank,sump,pistons,rings,rods, oil and water pumps,pulleys, cam belt, headgasket, cylinder head, newman cam and mechanical lifters (fiddly feckers), rockers etc all have been fitted just got a slight adjustment on a couple of the lifters to do then they are all good. just placed rocker cover on to keep any curse word out and also blocked off inlet/exhaust ports since the last pic was taken.
Mar 18, 2018 11:23:21 GMT
Mar 18, 2018 11:24:08 GMT
18-02-2018 my good mate karl was over again yesterday and gave up a good part of his saturday to help with building more bits of the engine up, also had time to build the new engine crane up (no pics sorry) turbo oil feed/engine mounts/ht leads/alternator/belt and crank pulley fitted. new cosworth oil pressure switch and stack oil pressure gauge bits fitted coil/dipstick fitted and quite a bit of time spent on getting the solid lifters bang on for the cam, very fiddly job for sure.
Mar 18, 2018 11:25:06 GMT
03-03-2018 not a great deal to update on, no progress was made last weekend due to other commitments and nothing will be happening this weekend for same reason and also down to karl injuring his back at work on monday. I'm hoping we can do some on it next weekend but will just have to see how things go, we really aint that far off finishing now.
otherwise i did recieve a few new bits, helix clutch release bearing and new reverse light switch. I also had my turbo crossover pipe repaired by a local engineering company and helicoiled by dave rushton. If anyone knows these cars they will know the 2 bolt hole areas on the pipe always seem to break away and thread wears out which means ht lead bracket is no use and they just sit all over the place in the hot engine bay which looks really untidy imo.
Mar 18, 2018 15:24:39 GMT
Thats bloody clean behind the bumper !
Mar 18, 2018 15:30:32 GMT
Thats bloody clean behind the bumper ! its surprisingly solid in there and the engine bay etc, i think we also did a nice job of fitting the airtec stage 2 radiator and stage 1 fmic kit. Its all hidden lovely behind front bumper and is a huge improvement over what was in there, oe rad was shot to pieces.
Mar 18, 2018 21:17:19 GMT
Is that a pottermus I spy in the top picture face down?
After seeing it i looked on full site to see area and spotted your a fellow oatcake eater as well, ay up duck!
Last Edit: Mar 18, 2018 21:22:44 GMT by fordperv
Mar 18, 2018 22:19:35 GMT
As in "cast kick a bo" etc ?? (Exiled Stokie lol)
Is that a pottermus I spy in the top picture face down? After seeing it i looked on full site to see area and spotted your a fellow oatcake eater as well, ay up duck! orate duck how at? it is yes mate haha, oh yes cant beat a few oatcakes As in "cast kick a bo" etc ?? (Exiled Stokie lol) against a wo, an yed it till it bosts once a stokie always a stokie
Mar 19, 2018 10:13:48 GMT
Well I hope I see you boosting around the local area in this little motor
I'm now thinking of happy memories of festival park
Mar 19, 2018 13:02:26 GMT
Well I hope I see you boosting around the local area in this little motor I'm now thinking of happy memories of festival park I am hoping to get plenty of miles on the car this year once the engine goes back in. Whereabouts in stoke are you fella? Also what motor are you currently driving or have a project happening with. Some great times down there back in mid/late 90s with my older brother in various motors.
Mar 19, 2018 13:52:19 GMT
I drive a black sapphire as my daily, ive got a couple of projects, a mk3 capri and a mk1 3 door sierra that I'm just waiting to go in for paint.
I'm also beginning a rebuild of the mrs S2 erst this year as it needs a paint job, she's had it 10 years and it's never had anything done while we've had it
Last Edit: Mar 19, 2018 13:53:22 GMT by fordperv
Mar 19, 2018 17:12:04 GMT
I drive a black sapphire as my daily, ive got a couple of projects, a mk3 capri and a mk1 3 door sierra that I'm just waiting to go in for paint. I'm also beginning a rebuild of the mrs S2 erst this year as it needs a paint job, she's had it 10 years and it's never had anything done while we've had it great stuff mate do you ever get to breakfast at the brewery at lymstone brewery in stone? cracking meet such a variation of motors.
Mar 19, 2018 21:43:53 GMT
I have been meaning to I keep getting asked by the ford lot I get to shows with, but a lot of the time I'm working unfortunately
