A6 Avant 2.5TDI in C4 flavour.
nearly 310k miles but fair condition. It's been developing a clattering/clonking underneath when travelling over bumpy roads (nearly all around here) for a few months now and it's starting to irritate! I'd fix it if I could only figure out what it was. I think it's coming from the front but it's one of those noises that if you have 4 people in the car they all think it's coming from a different corner (usually the one nearest them).
So far I've:
- Had a good hunt around for random loose objects under the bonnet and in the car and removed anything found - no effect
- Replaced all the exhaust hanging rubbers - no effect. Shaking the exhaust vigorously doesn't create any rattles.
- Removed all undertrays and run around like that for a few days - no effect.
- Change front top mounts - no effect
- Renewed RH TCA (they are known for eating TCAs) - no effect LH seems fine.
- Asked the MoT man to look extra hard (risky!!) - He didn't find anything.
- New engine and gearbox mounts - no effect.
It had front subframe bushes and rear beam bushes about 2 years ago and these still seem good.
The dampers are all KYB and have done maybe 100k. They seem ok (all still holding gas pressure) but should probably be renewed. Could internal wear be making them clatter? Not something I've noted before......
Any ideas?
TIA
Nick
So far I've:
Any ideas?
TIA
Nick
