Four alloy wheels, copies of Lorinser Turbines, one with slight kerb rash. Could do with a bit of a clean/polish but otherwise good. Centre bore is 65mm. Fitted with Vredestein 235/45 17s… reasonable tread but not used for 5+ years, so assume new rubber required for time reasons more than anything. PCD is 5x112 (Mercedes) but they were on my old T25. Good looking wheels. I’m after £100. Wheels are at my dad's house in Bradford and will need collecting from there. I can be contacted by PM on here or email mg261285AThotmailDOTcom Thanks, Matt
Last Edit: Apr 12, 2018 9:15:37 GMT by mattTR6
1972 Triumph 2000 – first car, long-term daily driver and all-rounder, done 65,000 miles in my ownership. Has a tuned 2500 motor and is used for a lot of long-distance touring events 1972 Triumph TR6 – US import, returned to the road in 2019 for the first time since '85! 2004 BMW 330d Touring – general hack, much mapped up goodness
Hi Matt, do you know what the offset and center bore is?
Cheers
ph47jat
Enter your message here...
Pmd you
Hi Matt, do you know what the offset and center bore is? Cheers Hi there, Sorry but I have no idea what the bore and offset is… been quite some time since I used the wheels. I can try and get my dad to check them to find out though. Cheers, Matt
OK… centre bore is 65mm. Haven't been able to confirm the offset, but some online research suggests ET38 is likely. Hope this is of some help.
Thanks, Matt
Cheers matt, i'll have to pass, i'd need too much spacer to get them to fit.
Apr 17, 2018 15:46:26 GMT
Cheers matt, i'll have to pass, i'd need too much spacer to get them to fit. No worries, thanks!
Apr 21, 2018 16:55:20 GMT
I love them, but haven't got anything they'd fit on (apart from the 190E, which would look hilarious...) - GLWS!
I love them, but haven't got anything they'd fit on (apart from the 190E, which would look hilarious...) - GLWS! You know you want to
