Hello
I'm after a N/S firenza door.. will settle for a hc door and a boot floor for the firenza. Sure hc fits. Or as much of a boot floor, as mine is not even there!
Thanks
May 30, 2018 10:51:52 GMT
How bad is the door you have?
Could probably make repair sections for the boot floor, I've done most of the hatch rear end but in smaller pieces.
May 31, 2018 16:03:14 GMT
How bad is the door you have? Could probably make repair sections for the boot floor, I've done most of the hatch rear end but in smaller pieces. Both of them are fairly bad. I've attached a picture of the boot floor and the picture is doing it justice, to what it really looks like in person! The doors are completely shot, so i managed to source a drivers HC door, so i could swap the window frames with.
May 31, 2018 17:46:38 GMT
Yes, that's quite similar to the hatch, with the added fun that there's a box section between the arches that has to be removed for access on the estate shell. As scabby as it looks, I'd say the section down the right would probably clean up, though maybe with a few little holes that could be patched. The ribs on the section between the arches are a fiddle, the bends in the panel mean that they probably need to be cut, notched and welded to make the turns, in the absence on the proper presses. I just looked at my old photos, it looks as if I made the ribs separately on that part and welded them in place.
