Jun 10, 2018 19:02:35 GMT
Help required! I have the seats below for my Midas (which is itself a tiny and very low car). With standard runners underneath my head touches the roof. I am only 5ft 8 1/2". I think I need different seats. Can someone recommend seats with skinny squabs that will fit easily and won't break the bank. When I bought the car the original seats (Huntmasters) were rotten - the runners had disintegrated and the cloth and foam was totally sodden. (Not surprising as the car had sat in someone's garden for a decade with much water ingress). They went in the bin as they were past saving (pic below).
Last Edit: Jun 10, 2018 19:03:37 GMT by mrbounce
Jun 10, 2018 19:56:04 GMT
longman
Club RR Member Number: 3
Jun 10, 2018 19:58:08 GMT
Does it have seat rails? , I had to remove these on my 911 as I'm 6ft 4 and don't fit...
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
Jun 10, 2018 20:03:35 GMT
quite a lot of seats have excess framework that can be trimmed away from the bottom. I fitted rs turbo recaros in my 924 this way. what about mx5 or early impreza seats?
Jun 10, 2018 20:09:44 GMT
Do you really like the seats you've got?
Could a car trimmer remove some foam and make good? My dad had foam removed from the seats on a couple of his bikes because he's on the short side, and they made it look like it hadn't even been done - I wonder if similar could be done to your current seats.
Because they're pratty rad if you ask me.
Jun 10, 2018 20:12:52 GMT
quite a lot of seats have excess framework that can be trimmed away from the bottom. I fitted rs turbo recaros in my 924 this way. what about mx5 or early impreza seats? I may have access to a set of MX-5 Mk1 seats but they're very tight height-wise. Apparently there's a mod that can be done where the seat foam is trimmed, but I really don't want to have to start faffing about modifying stuff anymore on this car - I just want it to fit straight in! The Impreza seats are too wide. Imagine a Mini with less width and no headroom.
Last Edit: Jun 10, 2018 20:14:57 GMT by mrbounce
Jun 10, 2018 20:13:39 GMT
MX5?
Jun 10, 2018 20:14:29 GMT
Doh! Cross-post...spent too long looking for a decent picture!
Jun 10, 2018 20:17:45 GMT
Does it have seat rails? , I had to remove these on my 911 as I'm 6ft 4 and don't fit... No seat rails on the car. Any runners would be attached to the seat and then to the floor.
Jun 10, 2018 20:19:01 GMT
Do you really like the seats you've got? Could a car trimmer remove some foam and make good? My dad had foam removed from the seats on a couple of his bikes because he's on the short side, and they made it look like it hadn't even been done - I wonder if similar could be done to your current seats. Because they're pratty rad if you ask me. Love the seats but the squab is too tall. It's an option I suppose but I would like to avoid yet more modification if possible.
Jun 10, 2018 20:23:16 GMT
MGF?
Jun 10, 2018 20:30:05 GMT
MGF? Oooh now there's a potential!
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
Jun 14, 2018 17:54:51 GMT
Last Edit: Jun 14, 2018 17:57:20 GMT by strikey
fulvia1436
Jun 18, 2018 14:12:28 GMT
Jun 18, 2018 22:50:35 GMT
