Per the title, anyone aware of other cars that use the 2.0 24v V6 that’s used in a 93/96 Mitsubishi Galant?
Am trying to locate an aircon compressor for one, and drawing a big blank.
Thanks!
alx
Club RR Member Number: 21
Jun 13, 2018 10:26:58 GMT
FTO uses the 6A12 engine, if that's the one your referring to. The Galant also used the 6A13 (2.5 V6) which I think will use the same aircon compressor. Mike at Viamoto will be able to give you more help such as common part numbers etc www.viamoto.co.ukCheers AL.
Last Edit: Jun 13, 2018 10:27:34 GMT by alx
Jun 13, 2018 13:52:28 GMT
Hi, Instead of looking for the engines try getting the name and any numbers off the compressor and searching for that. If you have no luck with that go to an air-con company and they will know what it is and can probably repair it or it may just be a case of changing your back plate over to a fresh compressor. Or failing that they could put an alternative comp on and re-hosing it to your car. Look for a company that does PSV or plant work as they will be used to that sort of work.
Colin
Jun 13, 2018 14:00:56 GMT
mitsubishi were working with volvo around that sort of time too - not sure if any of those parts were shared with galant though.
Milord
Jun 13, 2018 14:10:37 GMT
iirc the S40/V40 was related to the mitsu carisma.
No relation between the Galant and Volvo afaik
Currently: BMW E46 320i Touring BMW E34 525TDS Touring VW T3 panel van 1.6d Opel Kadett C1 Caravan 1.2 Fiat 411R
alx
Jun 13, 2018 15:24:06 GMT
Looking at the compressor ID for the FTO: MSC090C It brings up a few cars that use this same compressor Volvo V40 linkCarisma linkthere's a few more and it seems the Mitsubishi part number is MR315268 link
Looks like it's £835.69 from Mitsubishi There's loads of FTO's being broken these days so there should be no shortage of a compressor. HTH AL.
Jun 20, 2018 11:46:45 GMT
Thank you all for your input; sadly the knackered compressor has long since been chucked, so no hope of scavenging that to make something else fit (I've been asked for assistance a little to late really).
The broken compressor has model number AX105VSL4 with reference AKA201A230 - they've available on eBay by the looks, but he doesn't much like the idea of ~£350.
reliantreviver
"It will be getting fixed up come summer..." (year undefined)
Jun 20, 2018 12:18:33 GMT
Air con delete it is then!
Current: Reliant "750" Super Robin, Scimitar SS1s - 2 x 1300, 1 x 1600, 1 x 1800ti. 76 years off the road between them! Also - Mitsubishi Galant Sport and Hyundai Coupe Gen3
Jun 20, 2018 12:28:06 GMT
Thank you all for your input; sadly the knackered compressor has long since been chucked, so no hope of scavenging that to make something else fit (I've been asked for assistance a little to late really). The broken compressor has model number AX105VSL4 with reference AKA201A230 - they've available on eBay by the looks, but he doesn't much like the idea of ~£350. some ebay sellers list alternative part numbers on their listings which you can then go and search for separately. I saved £400 on a starter motor for my acty that way.
alx
Jun 20, 2018 14:29:49 GMT
Thank you all for your input; sadly the knackered compressor has long since been chucked, so no hope of scavenging that to make something else fit (I've been asked for assistance a little to late really). The broken compressor has model number AX105VSL4 with reference AKA201A230 - they've available on eBay by the looks, but he doesn't much like the idea of ~£350. 80 euro but in Portugal linky
alx
Jun 20, 2018 14:31:19 GMT
Jun 23, 2018 14:01:46 GMT
Air con delete it is then! The car is in Gran Canaria, so that’s not an option
