Jun 15, 2018 18:10:25 GMT
Hi all
1994 3.0td auto super custom ltd
Took battery out the other day. Replaced it last night.
This morning started as normal first turn etc. Drove usual daily drive me 20 miles to work.
Got in after work, started as usual however the battery light was on (not flickering) also three yellow warning lights. One the oil level, other the diesel fuel filter light one other that looks like a radiator.
Drove no issues for ten miles. Stopped for an hour and again started no issues and drove twenty or so miles back with no issues save for the same four lights on!
it all seems a bit coincidental that I have three dash warning lights and a battery light that have all come on in one go?
Any ideas?
Cheers
bm
Toyota HiAce Super Custom Ltd (My thing) Isuzu Trooper (her thing) Audi a4 1999 (boys thing) Toyota Yaris Caravan - (festi thing)
Jun 15, 2018 18:36:18 GMT
Battery engine off showing 12.35
Engine running 12.18
Jun 15, 2018 18:43:23 GMT
Jun 15, 2018 19:02:42 GMT
Cheers . .
Will check all fuses in the morning as for polarity diode where is it? Can it be changed or checked?
Cheers again
Jun 15, 2018 21:55:50 GMT
Many thanks
Jun 16, 2018 12:24:27 GMT
Fuse checked all okay. Also ran additional earth from battery to body. Not checked or messed around with diode thing but no change
Jun 16, 2018 12:25:10 GMT
If my battery is charging what problems will it cause running with battery light on?
Club RR Member Number: 160
1994 Hiace super custom battery lightRich
@foxmcintyre
Club Retro Rides Member 160
Jun 16, 2018 12:53:16 GMT
If my battery is charging what problems will it cause running with battery light on? Based on that voltage check your battery is not charging. General rule of thumb is if the light is ON, the battery is NOT being charged.
Jun 16, 2018 13:03:09 GMT
Reckon your right and it's alternator time
Update.
Alternator changed after fuse issue all is tip top reading 13.68 at tick over.
Cheers all 👍
FWIW I had this issue on my Mercedes.
When I ran that without no alternator belt it put all of the warning lights on in addition to the battery light. That included:
-ABS light -Fuel level -Coolant Level -Screenwash level -Oil Level
It was surprising!
It did mine and thought I had buggered ecu but all back to normal now
