adam73bgt
Club RR Member Number: 58
Jun 17, 2018 16:12:13 GMT
Going a different route with my B now, so got some B series tuning bits for sale Piper BBP285 camshaft for a B Series engine, I bought this a while ago and have never used it, still sealed in the bag, specs below taken from the Piper website £150 B Series Weber 45 intake manifold £100 Eaton M45/65 Supercharger, bought for the B but not used, turns nicely £200 4x114.3 wheel spacers, used on the B, should be fine for other cars with the same PCD, 20mm thick, 66.1mm centrebore £50 All parts can be collected from Bedworth, Warwickshire, or I'll consider postage on some of the smaller/lighter items Cheers!
Last Edit: Aug 14, 2018 13:18:29 GMT by adam73bgt
Jun 17, 2018 16:59:26 GMT
Aside of the supercharger how many other bits would be required to supercharge an MGB GT and do you have any of them, cheers
adam73bgt
Jun 17, 2018 17:10:14 GMT
Aside of the supercharger how many other bits would be required to supercharge an MGB GT and do you have any of them, cheers Buying the charger was about as far as I got really! MOSS do an all in kit for about £3k using a draw through SU carb system. My plan was to mount the supercharger on the opposite side of the engine and have an intercooled setup with EFI.. so depending on how you want to charge it the list of parts will be a little different. Basic stuff would be, a way of mounting the charger, a pulley for the belt (probably an idler too), fuelling from either an SU with Metro Turbo style seals or EFI or maybe even a weber, would want some way of adjusting the timing too, I think the MOSS kits have a re-curved dizzy, I was going to use Megajolt or similar and lose the dizzy
Jun 17, 2018 17:14:04 GMT
How much to post the spacers?
adam73bgt
Jun 17, 2018 17:36:19 GMT
How much to post the spacers? If I can find a suitable box to put them in, extra tenner on top for postage?
adam73bgt
Jul 29, 2018 20:25:14 GMT
Exhaust Manifold now sold, first post amended, stuff still available!
