Hi there, Am looking to lower my Volvo 240 estate this week, just ordering in springs, based in London UK Anyone got any recommendations? Also will I need to change the shocks or any other part of the steering? Cheers Paul
Last Edit: Jul 9, 2018 10:41:57 GMT by teamkeane
mylittletony
Club RR Member Number: 84
I recommend half of the original ones
mylittletony
Hi there, Am looking to lower my Volvo 240 estate this week, just ordering in springs, based in London UK Anyone got any recommendations? Also will I need to change the shocks or any other part of the steering? Cheers Paul Only slightly more serious, classicswede stocks various springs. Commonly available -40mm lowering springs only bring the car down a bit from it's stratospheric normal ride height to normal car height, not actually lowering. Gaz shocks are available in different lengths, any seller will of course recommend you buy shocks at the same time but you don't need to, depends how good the existing ones are and how low you go. There's also people who will insist you need to buy a steering spacer to go between lower arm and strut. I haven't and mine handles just fine, entirely depends on what you plan using it for. (basically re-levels the lower arm, reducing the positive camber change through suspension travel)
Cheers thanks, will get in to them. My other thoughts were no cut down a new set.
Jul 10, 2018 12:36:29 GMT
I need to get onto classic swede for lowering springs for my 940 turbo too
Jul 10, 2018 13:26:47 GMT
Yep went for coils all round, PRICY - springs and shocks were the most cost affective but I wanted to lower it to the ground, so will let you know how I get on Thursday. The mentioned that I would need a brake fairing kit any suggestions?
Also, is it possible to bolt on a turbo to a 92 240 SE estate, seen a couple of posts that you can. Its a 2.3 fuel injected?
just a thought
Jul 10, 2018 13:40:48 GMT
Hi there, Am looking to lower my Volvo 240 estate this week, just ordering in springs, based in London UK Anyone got any recommendations? Also will I need to change the shocks or any other part of the steering? Cheers Paul Only slightly more serious, classicswede stocks various springs. Commonly available -40mm lowering springs only bring the car down a bit from it's stratospheric normal ride height to normal car height, not actually lowering. Another vote for ClassicSwede. Got the 70mm lowering springs when I had my 740 saloon, sat just right and not stupidly low at all. 70mm brings it down to the height of a normal car... Still very comfy too and handled like a totally different car. The 240 next to my 740 above is on cut springs. I do think after a while the 70mm ones would have an impact on the shocks though, my rears started to sag a little when I sold it but not sure why that was. It had cut springs on beforehand (although they were cut to within an inch of their life, 2 coils left at the front!) which were shocking beyond belief. If you just cut 2/3 coils off I believe they are okay (if a tiny bit bouncy) - but getting an MOT is a bit of a weird area with cut springs. Yep went for coils all round, PRICY - springs and shocks were the most cost affective but I wanted to lower it to the ground, so will let you know how I get on Thursday. The mentioned that I would need a brake fairing kit any suggestions? Also, is it possible to bolt on a turbo to a 92 240 SE estate, seen a couple of posts that you can. Its a 2.3 fuel injected? just a thought Not really - think the engines aren't as strong and you'll need a new wiring loom or ECU. Non-turbo transmissions aren't as strong either. Better off just getting a whole donor turbo and doing a swap.
Jul 14, 2018 20:58:08 GMT
These no good "cheap" way unless your handy with fabrication The biggest problem is Volvos are so high std you need to remove quite a bit of spring to get them down But then the shock run out of travel The front struts I made for my 240 cost about £150 The front struts I bought from gaz for my 940 cost £550 I'm not overly impressed with the gaz build quality
1992 240 Volvo T8 1955 Cadillac 1994 BMW E34 M5 (now sold ) 1999 BMW E36 sport touring x2 1967 Hillman imp Californian "rally spec" 1971 VW bay window (work in progress) 1999 Mazda 323F 1987 Jaguar XJ12 All current
Jul 15, 2018 20:20:34 GMT
That was mine many moons ago. Rmad and I cut the front springs on the car.....yeah I know. It honestly drove fine after, still took a load and towed my folding camper no problems.
Last Edit: Jul 15, 2018 20:21:27 GMT by wagoneer
Peugeot 307sw - Suzuki SV650S - MX5.
Club RR Member Number: 160
Jul 15, 2018 20:44:31 GMT
getting an MOT is a bit of a weird area with cut springs. Ah, this again. No, it isn't. From the MOT Testing manual:
Jul 16, 2018 20:08:17 GMT
Started off well. The brake pipes are a nightmare, constantly snap
Can anyone recommend any alloys? I have a set of 15 inch virgos going if anyone wants them, and a set of steels that are originals with the car
Jul 16, 2018 20:10:19 GMT
mylittletony
Can anyone recommend any alloys? They're hard to come by in the PCD and offset required. Either buy new, or spacers and modern volvo wheels, or adapters and whatever you want.
Been a while, but finally getting round to finish her off. I now need a set of adapters for the bbs wheels I bought. Can anyone recommend where to go? The stud pattern for the volvo are 5x108 center bore 65.1 to the bbs which is 5 x112, centre bore 70mm?
Hi there, Am looking to lower my Volvo 240 estate this week, just ordering in springs, based in London UK Anyone got any recommendations? Also will I need to change the shocks or any other part of the steering? Cheers Paul Being a pedant, the springs are the shock absorbers :-) I think you mean the dampers. No change required to the dampers as long as there is still spare movement available on the damper rod (ie it hasn't bottomed out) when the spring is fully compressed or suspension hits the bump stop.
