Hello here, desperate plea!!!
I had a key cut for my 205 from a high street key cutters and it never worked (even after a re-cut) properly. It worked on the drivers door but not the passenger door, boot nor ignition. The original is (was!) fine.
I have mislaid the original so I have problems!!!
What I would firstly like to ask is could the new one that was cut not work properly as the old one was worn?! Could a bit of ‘wearing down’ make it work?!?!?!
Secondly, can I get an original key cut from the chassis number or engine number?! I’m in a bit of a predicament!!!! As it has an after-market petrol cap I’m in even more of a bind but I just need to start on the master key...
HELP!
Thank you all so much in advance...
HELP!
