Morning all, for some reason I have never posted anything about this build on RR (if I have I can't find it anywhere), so the first part will be copied and pasted from another forum to give you the whole story..
Starting almost 2 years ago!
I have started a little project that I have been meaning to do for a long time, a panning camera jig thingy..
This should make my videos look more professional and hopefully make them more enjoyable for you all to watch...
The first part needed was the gearbox out of this very old and abandoned kiddies electric car..
I forgot to get a photo of the gearbox so here's a pic of what remained of the car when I'd finished cannibalizing it.
While dumping the remains of the car on the rubbish pile I thought I'd have a quick look at the scrap pile...
Hhmm... Those tubes could come in handy
Back in the workshop some choppy weldy later, a 8 inch wide tubular track was made.
Now I needed something to roll along the track, a sliced up cart axle and some used bearings got things rolling..
Yes I did commit the sin of welding the bearings to the axles, but the bearings feel the same as before the welding so hopefully all will be well.
Something to mount the camera would be handy, so an old tripod got the chop.
To motorize the contraption I am using a CB radio power pack, a New Holland tractor wiper motor and the speed control gubbins from a rechargeable drill that has knackered battery's.
The two axles were joined together by using a cut down New Holland tractor wiper motor bracket which just happened to have the right size hole to fit the tripod cut off.
As you can see the wiper motor isn't fully fitted yet.
The idea is the wiper motor slowly winds a length of string onto a shaft and pulls it along the track..
The speed control does work but the motor does make some squealing sounds at slower speeds.. Something to have a think about..
I will add the electric car gearbox to slow things really down whilst doing time lapse filming.
