Hi Will look them out and post some pics up not sure if all the rear clips are good but the trims are good no dents Hi Kinda spoke to soon this set has scratch's on the rims and no clips which i had forgotten about i had bought them along with other sets off a fella clearing out his Mercedes spares if there any good to you let me know ,,,looking for what i paid for them which was £40 Clips etc aren't too much of an issue, we can deal with that with cable ties if necessary. Could you take a measurement of the depth of the bowl from the outer rim? I've got a similar looking set of trims here which weren't deep enough to clear the dish in the wheels on the van. Annoyingly I can't find a photo to compare yours to though I know I have one somewhere!
Jun 29, 2021 10:43:41 GMT
outer rim depth is 1 inch
center depth middle of the bowl is 1;5 inch
hope this helps
Sept 30, 2021 16:12:56 GMT
Hello I've just purchased one of these and in need of a few parts, I'm struggling to find cab doors......any ideas
Hello I've just purchased one of these and in need of a few parts, I'm struggling to find cab doors......any ideas It's a tricky one...panels aren't the easiest to find over here these days. Coastal Motorhomes tend to be one of the best options (if not the cheapest), but they're not showing any door repairs in stock at the moment. You might have better luck seeing if you can find a source on the Continent where these vans seem to be a bit less uncommon. Though shipping for something as big as a door wouldn't be cheap.
Hi thanks for the reply, i have located to broad but struggling to find a courier to collect them
Oct 24, 2021 20:32:00 GMT
The leisure battery in this has been showing signs of having died a sudden death recently. Dropping like a stone to around 10V pretty much as soon as any load is applied. Before consigning it to the recycling bin I figured it made sense to at least check the electrolyte level, as a visual inspection can often reveal signs of damage too. The label helpfully said to remove the sticker for maintenance...so I honestly expected to find cell plugs under it. Yeah...about that. Strikes me as an odd decision to render this sort of battery unserviceable given by its very nature as a leisure battery it's likely to spend a lot of time on float charge when the vehicle is in use or in standby ready for use. In this case all it told me was that yes it's toast. The electrolyte in all but one cell is the colour or strong black coffee and on closer inspection the one end of the battery has bulged out by about 1/4" That lip below the lid is recessed on the opposite end. Something has gone quite badly awry in this battery. New one is about £100, not the end of the world but a cost I could have done without. I think I'll probably look to make a bit of a change to the charging/DC supply in the near future too. The current onboard charger is a pretty old school one, and just supplies the DC circuits in parallel with the battery. Given that I'm in and out of the van quite a bit and like to leave the heater powered on in frost guard mode in the winter that means it spends quite a lot more time on charge than is ideal. I think I'll set things up so instead I have a separate mains to 12V DC supply to run the onboard services when mains is hooked up and a separate proper intelligent charger to look after the battery. It's a pretty trivial matter to use a few relays to switch automatically between the battery or mains DC supply depending on whether mains is present. That will mean I can leave the van plugged in indefinitely without having to worry about it frying the leisure battery - but equally know that it's always ready to go if and when I go to use it. To be fair kits probably already exist to do exactly what I'm suggesting off the shelf...be curious to see how horrifically overpriced they are as generally seems to be the case for most things aimed at campers or caravans! DC supply shouldn't be difficult. By far the heaviest load is the heater during startup/shutdown, but even that's fused at 15A, though the highest draw I recall seeing during testing was around 10A...so doesn't need to be anything too specialised.
Having temporarily removed the leisure battery while I await arrival of the replacement I figured it would be prudent to remove the fuse from the split charging system. I've isolated the leads anyway, but better safe than sorry. The main vehicle battery box is something I've barely touched since I got the van. I've simply had no real reason to. The white in line fuse holder is the one for the split charging circuit. When reaching for it I couldn't help but notice the random blade fuse taped to a pair of spade terminals next to it was hot. Like REALLY hot. "I'm surprised it's not actively smoking" levels of hot. A little bit of investigation revealed this to be the DC feed to the fridge, which apparently I'd accidently switched onto DC mode at some point. Being designed purely for use when in transit to/from places that's set up so it will only be powered then the vehicle charging system is active. While the fuse hadn't blown, this clearly isn't up to the job! It was about this point that I discovered that the battery wasn't bolted down either. That was fixed first. Would have liked to have realised that about 10,000 miles ago... While rummaging around down there I found this bit of plastic. It looked familiar but took a good couple of tens of seconds to figure out what it actually was. It's edging fitted to the front seat frames, like this. The outer one on the passenger side has been missing since I got the van...now I know where it ended up, and have refitted it. I ended up replacing the weedy bit of wire with a maxi fuse holder I had in stock. It's overkill for the application, but is still fused at 20A...and I'd rather have low voltage DC wiring over-engineered than the alternative. It's hard to see in the photos but all of the other lines going into the split charge relay are beefier than this one was. I wound up doing a bit of general tidying up and housekeeping...not least actually bolting down the relay rather than leaving it flapping in the breeze as I assume it has been for the last 31 years and labelling the fused lines and battery isolator. Not as though you'll ever see any of this as it's hidden under the passenger seat! Nevertheless, after running it for half an hour I confirmed that the terminals of the new connection were just barely warmer than ambient...a large improvement from the starting point! So I'm happy it's been sorted even if nobody will ever know. New hardware is on the way in the form of a new 110Ah deep cycle battery (identical to the old one), a CTek intelligent charger and a 40A DC power supply. With a little rummaging in the box of relays I should be able to get this set up with an automatic switchover and give us a properly looked after battery going forward irrespective of how long I leave the van plugged in for. I've never had any starting issues even at -10C up in Scotland, so don't think I see any reason to make provision for charging of the vehicle battery from the mains too. If I get that desperate on the road, that's what jump leads were made for...once the engine is running all this requires is enough power to hold the stop solenoid in on the fuel pump. I will replace that white in line fuse holder when I set about wiring the new kit up, probably with a similar Maxi fuse holder as I used for the fridge line, simply because they're good for way more power than we'll ever see here and I've found them to be nicely robust. Bit harder to find fuses for, but nothing carrying a spare or two isn't enough insurance against (carrying a decent stock of spares in something the size of a small house is less of a headache than in a car!). More and more cars seem to be using Maxi Fuses these days anyway so most factors seem to stock them - albeit not always down to values like 15 or 20A. Probably because they're total overkill for those ratings. This will be nice to have done as I can just leave it plugged in through the cold and damp weather without worrying about cooking the battery. The heater is set up to kick in if the cabin temperature drops below 5C or the humidity gets above 70%. Found last year that it pretty much completely eliminated issues with mould and mildew. I have the ability to control it over our home WiFi too, so it's really nice on a cold day being able to pull the modern EV trick of turning the heater on before I go out, then open the door to a nicely toasty warm van. It's hardly essential but is nice to have - especially as I do tend to use it as both a workshop and a bit of an escape space if I want somewhere quiet to retreat to for a while. I know I've sung the praises of the Afterburner controller before, but it's a cracking bit of kit.
Oct 26, 2021 23:42:18 GMT
Huge box from Tayna Batteries arrived earlier today which weighs about the same as a small planet. Really quick service as usual for them. That people, is how to pack a battery. A good 3" of padding on all sides (I've removed it from the top), foam wrap and double bagged inside that lot. Took me the best part of ten minutes to dig my way into it. Unlike the last one from eBay which came in a single wall cardboard box with a bit of bubble wrap. State of charge indicator shows healthy, though obviously first thing I'll be doing after it's installed is giving it an overnight charge. I note that the "remove label for battery maintenance" text has been removed from the label since my previous one was made. About an hour later another box arrived with this in it. It seems to work at least, plus side it's got a manual adjustment for output voltage which means I can bump it up a little from 12V closer to what you'd expect to see from a charged 12V battery. I only had 100W or so of load handy to test it with so far but it behaved perfectly with that. Not exactly hard to figure out how to hook it up. Not exactly the last word in quality in the fit and finish department, but I can't see anything that rings any alarm bells. For £22 delivered I've zero complaints - so long as it doesn't pack in after a week anyway. I'll probably make some standoffs for it to attach to so it doesn't struggle for airflow - the fan draws in from the bottom and sides so if I mount it flush overheating might be an issue. Not that it will generally be running anywhere close to it's rated capacity for any period. I'm also going to be mounting it to a vertical surface (probably rear wall of the "electrical locker" as I refer to the rear of the space under the sofa/bed) so if we ever have any issues with water ingress through the outer hatch just forward of that area it should be kept well and truly clear of it. Just seems like a sensible precaution...the old school transformer and linear regulator setup would be rather more forgiving of damp than a switch mode supply like this. Need to engage my brain a bit with regards to wiring things up, but pretty sure I can get an automatic switchover sorted out with a handful of components and some brainpower...quite possibly a single double pole relay could do it...Absolutely sure I can do all the switching on the 12V side...mains can just be left "on" to everything permanently (I'll incorporate a switch anyway for service purposes, but you get the idea). There are a handful of things I'd like to tidy up while I'm doing this work too - not least getting rid of the last few inline glass type fuse holders. There are a couple of redundant wires that can be binned, one or two to be rerouted actually under the floor, and I'd like to beef up the wire that's actually used for the split charge charging line...it just *looks* weedy to me for the application. Oh, and a bunch of grounds which run *aaaaaaaall* of the way back to the battery. Zip tied to the nice chunky metal chassis rail. Which being a van/truck chassis has a plethora of bolt holes, mounting eyes etc all over the place...they're getting abbreviated and terminated to the chassis and a beefy earth strap just run to the leisure battery - which should reduce the spaghetti in the leisure battery box by about 80% in one shot. I imagine it should eliminate a lot of the voltage sag we see when the water pump runs a bunch too. Said water pump may get totally rewired anyway... there's something not quite right with it on the control panel (it's causes backfeed into some of the indicator lights on the panel and way more volt drop than I'd like...so the switch may be repurposed to run a remote relay). The inverter is getting tweaked too. It's only really there as insurance against needing mains in an emergency, and is the sort of thing you can run a battery down with in a hurry - so I want to hook it up to a potential relay same as the setup for the fridge so it can only run when the engine is running and the charging system is live (the idle speed is slightly too low for it to wake up until you blip the throttle). I actually quite enjoy stuff like this - not so much while doing it, but standing back and looking at the end result and actually seeing an improvement or how much better something works is worth it. I'm seriously considering just taking a few days away before the weather gets too horrendous to go have a wander around up north. Aside from one overnight trip to collect the S123 I've literally not been more than 40 miles from home since November 2019 and am going *sliiiiightly* insane. Got a couple of friends who can loan me a parking spot and mains extension lead which is all I need with the van, otherwise I can be totally self sufficient. Insulation does just fine even in sub zero temps with the heater, I've got both hot and cold running water, TV, fridge, comfy bed, oven, grill, hob, perfectly usable bathroom, shower, eight USB charging sockets around the bed, and shedloads of storage. What more do you need for a few days away?
Oct 28, 2021 11:23:12 GMT
Zelandeth, assume you've come across David McLuckie's channel on YT. Haven't got one of those diesel heaters myself yet (no van)but fitted one to a mate's Sprinter camper recently, and the next job is an afterburner and one of those Bobilvans things for a shower. I'm mad to get a van but the price of anything not rotten has gone absolutely bananas recently. That and no space...
jamesd1972
Club RR Member Number: 40
Oct 30, 2021 17:32:09 GMT
What more do you need for a few days away? Beer? Nice improvements. The charging / electrical side of old vans appears to be a dark art to many and good to see somebody with a bit of an idea sorting things out. James
Last Edit: Oct 30, 2021 18:27:31 GMT by Rich
glenanderson
Club RR Member Number: 64
Oct 30, 2021 17:50:36 GMT
The charging / electrical side of old anything appears to be a dark art to many… FTFY. It never ceases to amaze me, the bodgery that some people undertake.
Oct 30, 2021 22:34:51 GMT
Planning to make a quick run up north later in the week in the van. With a long run ahead I decided it was time to finally get around to finishing sorting out the audio in the van...being able to even hear that the stereo is turned on above 40mph would be nice. After a search covering approximately 80% of my house I eventually unearthed this pair of speakers which I've owned since 2005 if I'm remembering right, but have never actually been properly installed in a vehicle. They came as part of a package deal including a sub and amp (which were what I was after) and all the stuff that went with it. Really was a case of a whole car audio system in a box, just add your own head unit - though the shop did have a variant with that too. The sub is actually still in use as part of my stereo inside, albeit having seen very little use actually in a car. These should help out quite a bit compared to the little 10cm ones in the dash. There aren't a huge amount of places I can really put them without adding in unsightly surface mount boxes, the obvious spot being in the forward facing sides of the seating/lockers immediately behind the cab. I'm loathe to go cutting holes in things...but improving audio is high enough on my list I'm willing to do it. If some future custodian really wanted to undo it, at the end of the day it's just two panels of plywood laminate they'd need to replace. Nearside is easy enough. The offside however is a bit busier because I've already installed equipment here in the form of the outlet, switch and status lights for the inverter. Right in the way. After a bit of thinking I've decided to rotate the speaker through 90 degrees and move the outlet, probably to sit directly below the switch. That bundle of wires you can see there is on my list of bodges I inherited with the van I hopefully will get rid of shortly. I'm planning to vastly simplify the DC wiring when I add in the new power supply and charger setup. Currently every circuit has its own feed all the way back to the battery, instead I'm going to install a beefy cable to a distribution point in the locker right next to the power supply, where it can then split off to the relevant circuits to get rid of a lot of the voltage drop - probably via an actual fusebox so I can get shot of all the remaining in line ones. The current setup is just a mess, for all I have removed quite a lot of bodgery compared to when I first got the van. Another wiring change I'd like to make would be to allow me to run the stereo off the accomodation power, as it would be nice to be able to run that without worrying about draining the vehicle battery. I hadn't been in the nearside locker for a while...like in a couple of years. As evidenced by there still being a mains fan heater in there... I've had working heating since sometime in 2019! It will come as absolutely no surprise to anyone who has ever been unfortunate enough to witness me undertaking anything resembling carpentry that things pretty much immediately descended into farce. Eventually we got to this point. You are not getting to see what's behind the panel. It is seriously ugly. The other side first required me to remove the socket, but followed a similar theme. Likewise, you're not getting to see the carpentry here either. Especially as a fair portion of it had to be done by hand as I couldn't get in there with the jigsaw. I'll reinstall the socket shortly, probably directly under the switch. I may go back and add a cover of some sort behind the speakers, partly as protection for them and partly to hide my absolutely hideous carpentry. Will be curious to see how this sounds - has to be an improvement over the tiny dash mounted ones though. No I've not discounted the idea of adding a sub in the future. That's a job for the future though. Would really like to get some better ones actually in the cab too, though that's difficult without actually cutting holes in metalwork which I'd rather not do. Last job for the day was to give the new power supply a test run. With everything on and the heater in preheat mode and the leisure battery disconnected the line voltage stayed rock steady at the voltage I set it to. At a guess that's with about 15A being drawn. So looks like that will do the job just fine. The fan speed is load dependent, but even at full chat (well, the loudest I've heard it anyway), it's just a distant bit of white noise once the locker is closed. Definitely won't be objectionable for the intended use. The little round pin socket, before folks ask is a DC outlet. Only thing I generally use it for is the water transfer pump for filling the onboard tank from the portable one. Though as part of the electrical improvements I might install a cigarette lighter style outlet in the locker so I don't need to run in and out of the van during the filling operation - I'd probably replace it with another mains/USB combo, one thing I've learned is that in 2021 you can never have too many USB charging points.
Today's main mission was to get the speakers I had just fitted wired in. I was not looking forward to this job as chasing wiring through the cab of the van is a royal pain as there's not much that comes off to hide it behind. Helpfully I discovered that the speaker wiring for the original rear speakers in the ceiling of the living area runs through a grommet in the floor under the fuse box, across the rear cab chassis support and then up into the bodywork. This meant I could reuse the bit between there and the head unit - I just snipped the wire under the van and dropped a cable tail down from the lockers right next to the speakers. Easy. I've left the original wiring in place as my intention is to wire those up to the monitor in the back, giving us a self contained entertainment setup without the need for standalone speakers or anything. While crawling around I discovered that the reversing light switch (which doesn't work) is actually external to the gearbox, attached to the back of the gearchange linkage. I'll need to have a poke around at that and see if it can be adjusted/repaired or if it needs replacing. Could even just be old grease that's dried up over time. While crawling around I had a hunt for something which has been bugging the heck out of me since the day I bought the van - an extremely annoying rattly buzz (or buzzy rattle) which appears whenever the engine gets anywhere towards the top end of the rev band. Which equates to any road speed above about 55mph. I was pretty confident this was something to do with the handbrake cable. I originally thought it was coming from here where the cable passes through a chassis member. Turned out that wasn't the culprit as putting a rubber sheath over it made precisely zero difference. A little more digging tracked it down. It's the cable return spring that's rattling against the little eye it passes through. I'll need to see if I can find a parts diagram to see if there should be something else there - it feels like there should have been a rubber boot or something to prevent this being an issue - as it seems like it will always have done this. I know mechanical refinement was never really the top of the priority list for a vehicle like this, but a noise as maddening as this surely never would have been considered normal. I note that there are two holes in the cable yoke with nothing on them, I do wonder if there should be a spring or something hooked on there. The speaker installation by the way appears to have been a success. While not stellar it's at least half decent now. Decent stereo separation, good chunk of bass and no real distortion - especially as the heavy lifting is now being done by the 6x9s rather than the tiny little speakers in the dash. Last job before I downed tools was tweaking the offside wiper arm a little as I noted last time I was out in the rain that it was fouling the side of the windscreen. Dropped it down by a couple of splines on the spindle and hopefully that will do it. There's no real way to get the wipers looking both tidy and have decent coverage. Not sure if this just something unique to the right hand drive vans or if they're all like that. Oh, and I managed to fill three full size rubbish bags with bits and pieces between the nooks, crannies, drawers, lockers and pocket dimensions.
460 plus change miles covered today. Three things to note. [] Is there a running difference between the cheapest diesel I can find and She'll V-Power etc? In this engine, absolutely. Definitely less willing to rev cleanly on the cheap stuff. [] The clutch pedal squeak is back. I was wanting to tear my own ears out to free myself from it after about three hours. It's getting some attention tomorrow. [] I really do need to do something to tame the exhaust noise...I love the throaty, raspy side of it, but not being able to hear yourself think between 40 and 69mph gets wearing after a few hours. Really is quite roomy when by yourself. Currently it's 6C and tipping it down outside... I'm quite happily listening to it on the roof and am just as warm and comfortable as I would be in a real hotel room. Heck, every single hotel I've been in in living memory I've had to take my own extension lead with me so I could charge my phone near to the bed... I've got four accessible USB charging points here within arm's reach and an extra two if I open a locker up. Take that Premier In...
Having barely left the concrete jungle I live in for the last two years (almost to the week actually) this is a nice change. This is the traditional spot where I usually snap a photo of my cars up here. Lada and Jag have been the only recent ones missed...and the Jag will be living less than 20 miles from this spot in the future so I'll be arranging that to happen one way or another! The Invacar I still really want to do the round country run in so would obviously happen then. Merc S123...well if the engine doesn't grenade itself in the next couple of months we'll see. Kinda sad I never got the Lada there, just never had the opportunity...being 450 plus change miles from my current driveway means it's not a trip I can just make on a whim! Definitely isn't enjoying the cheap supermarket fuel. I'm sure the actual difference is absolutely tiny, but in a 2.8t brick with 78bhp to work with and the aerodynamic profile of a block of flats it doesn't take much to be noticeable. Dealing with a bit of a headwind on the first half of my drive out today and I was barely managing to hold 50 in top gear, even the slightest of gradients necessitating a drop to fourth. The return trip, bounded along at 60 in top gear without a care in the world, only a couple of the steeper hills requiring me to drop gears. You always notice a headwind in this, but the difference usually isn't so dramatic unless it's really strong. Guess it shows how much on the knife edge of the performance being acceptable the van is. Given none of the stations around here have premium fuels I'll have a nose around to see if anywhere sells any of the cetane booster treatments.
Last Edit: Nov 5, 2021 0:14:10 GMT by Zelandeth
Stick a gallon of kero in it to boost the cetane rating. It's acceptable legally as an additive.
Nov 10, 2021 22:37:27 GMT
One issue I noted while out last week with the van was that the freshwater pump had sprung a slight leak. The leak was tiny, however it meant it kept losing prime. A bit of digging found a seal kit for £30 odd but couldn't actually find any in stock...or for literally £7 more including delivery... Yep...whole brand new pump, on my doorstep in less than 24 hours. Made in Mexico rather than China too, not been sitting around on a shelf for years either. Old leaky water pump... I'd forgotten the pipework in here was still such a mess. I really need to tidy this up at some point. Old and new next to each other to make sure everything matched up. Yep, aside from the label they seem to be identical. The silicone sealant oozing out between the two halves of the pump casting suggests to me that someone has had a shot at sealing this up before. New one in, correct way up this time round. The instructions suggest that the motor should be at the top if vertically mounted. The strainer is bugging me...the threads are such that I can't position it in a useful direction. Needs a bit of tidying but is working fine... reckon the old one had been struggling for a while as this now primes several orders of magnitude faster than the old one and provides a much smoother flow.
Nov 11, 2021 14:46:53 GMT
Wrap some PTFE tape round the thread of the strainer, till you get it to the position you want
Very quick job on the van a couple of days ago. Can you spot it? New air filter. The old one still wasn't quite due by mileage but has been in there since a couple of days after I bought it and was looking quite grubby. The whole housing being part of the filter means it's a bit more expensive to replace - but means changing the filter is literally a ten second job. One spring clip then the whole thing just pulls off. Have oil and fuel filters waiting to go on too, so will see about getting those done shortly. The old water pump had definitely been got at with silicone and instant gasket. Old pump was rather full of gunk, evidenced here by what was built up on the pressure switch. Eww. Kind of glad I pulled it now...definitely think the system will be getting rather more aggressively treated this year as I don't want that stuff growing in there.
Jun 21, 2022 17:43:39 GMT
Been a while since I've had to wave any tools at the van. Starting to get back into a functional state for my part again I figured that starting to tick off a few things on the to do list on it wasn't a bad idea. One of these has been changing the thermostat. Pretty certain it's never fully closed as long as I've had the vehicle. I've generally found the van bits of this vehicle to be very easy to work on, though the coach built bits have tended to make up for it. It appears that the thermostat however is the exception that proves the rule and is going to be a bit of a faff to change. Was a bit of a faff to *find* never mind change! Conventional wisdom places it where the top radiator hose emerges from the head. That's not even visible from under the bonnet, so passenger seat and the engine cover were removed. The top hose is just about visible buried under the fuel system here, though anything that looks removable that's big enough to contain the thermostat is conspicuously absent. A bit of head scratching and standing on my head appears to have located it, rather oddly kit seems to be at the engine end of the *bottom* radiator hose. Odd setup...and not exactly easy to get to. It's sandwiched between the exhaust manifold and offside engine mount, tucked behind the alternator which precludes any thoughts of access from the front. Near as makes no odds the lowest point in the system too so definitely be a coolant drain as step one... inevitably I'm going to end up with several litres of coolant in the face doing this job though. The coolant is due a change anyway so I don't mind having to drain it...just don't particularly want to wear it. May end up being a case of "screw this, a garage can do it!" depending on how awkward access ends up really being when I try to get tools onto it. Need to clean the whole area up too as the timing cover gasket appears to be leaking to no small amount...again. Will probably blast this area down with degreaser then hit it with the pressure washer first though as I'd like to confirm if this is coming from the timing cover or oil filler neck extension (bolted to the timing chain cover as in the van application the normal filler is inaccessible) before I go blowing £30 on another gasket for the timing cover. That combined with running several errands however has consumed my available energy reserves (and patience with being eaten alive by ants), so back hiding in the air conditioning for now.
