Had a go at starting the Humber today after finally going and buying a funnel to put some petrol in. It turns over and begins to fire but as soon as you let go of the key it cuts out.
Fuel is then curse word out of a "plug" on the bottom of the float chamber. There is one big plug on each carb.
What would cause this leak? I've tried changing the plugs to see if the rubber seal was knackered but it made no difference.
I am thinking the needle valve is buggered or the floats have pinholed and flooded but i've no idea with this sort of carb.
Matt
Matt
