Apr 26, 2019 21:36:42 GMT
I'm putting together a Speeduino EFI and i'm now kind of thinking that I chose the wrong coil as i can't find a suitable connector. So can anybody help me find a connector for this coil VAG 021 905 105. VW VR6 5 pin rectangular. I thought it was one of these , but it turns out it isn't.
Apr 26, 2019 23:28:17 GMT
Assuming it's a Bosch part try cross referencing the part number, try googling.
Apr 26, 2019 23:59:54 GMT
Pretty sure it's 5 pin EV1 from memory {I used to work for Bosch Diagnostics a long time ago!}, try looking on a VAG website.
Ignore last comments....4DO973725 round terminal 5 pin, pretty sure thats the one.
Not that one unfortunately. This is the problem i'm having stevo67 . If I had bought the later VAG version or even the Ford version it would have had the rounded plug, I need the rectangular one. I just can't find it anywhere. Worst case i'll just have to wire up spade connectors on to the terminals. Thanks for trying though.
tristanh
Routinely bewildered
Apr 27, 2019 10:27:49 GMT
Looks like a Packard timer? Common to the mk2 Golf era. And used on a breakout cable at the ECU of the 8v GTI Digifant.
Phil H
Club RR Member Number: 133
Connector identification Phil H
@philhoward
Club Retro Rides Member 133
Apr 27, 2019 10:33:06 GMT
I’d agree with it being the Packard variant bu5 I struggled to find anything but the 2 and 3 pin versions?
Apr 27, 2019 10:35:35 GMT
Apr 27, 2019 11:34:39 GMT
Nope, it isn't a junior power timer connector, that is what i bought, I have one here and it doesn't fit.
Apr 27, 2019 11:50:28 GMT
post it on clubgti , theres a guy on there that can help
tristanh
Apr 28, 2019 22:42:26 GMT
Rubjonny. But definitely the mk2 gti 8v has that type of connection as I mentioned above, in 5 pin.
Apr 29, 2019 12:33:38 GMT
Hard to tell, but I don't think it is. Packard timer seems like a good call but i can only find 2 or 3 way just like has been said. Could somebody ask on a VAG forum for me? I'm not a member of any of them.
Apr 29, 2019 13:34:34 GMT
Last Edit: Apr 29, 2019 13:41:06 GMT by omnipod
Apr 29, 2019 16:03:55 GMT
Try Vehicle Wiring Products or 3 way components
Last Edit: Apr 29, 2019 16:09:13 GMT by Deleted
tristanh
Apr 29, 2019 16:10:59 GMT
Hard to tell, but I don't think it is. Packard timer seems like a good call but i can only find 2 or 3 way just like has been said. Could somebody ask on a VAG forum for me? I'm not a member of any of them. I already did, plus I had to effect a repair on one of the numerous GTIs I maintain, on the exact plug I'm suggesting, last weekend. DubShack (Brendon Moss) probably has loads.
tristanh
They're slightly different.
