adi
Ok so I'm planning my next project. I actually really like my R53 mini, but I also love my 20vt mk4 golf. The engines are cheap, make good power cheaply and reliably, but 20vt in a mini has been done 6 times that I know of... but 2? Nobody has been that adventurous yet.
I know of a twin engined R53 in America that uses 2 curved motorcycle rads in the rear quarters and IC in the roof so I'd go with that.
But I don't like how he's done the cable change setup so what's my options with that? I'd like to easily disconnect one.
Without getting into a huge legal discussion will it be an IVA thing? Tbh I don't care if it ends up on a Q plate. The car will most likely be a £300 clutch/engine fail cooper
I know theres a few on here that have done this and the principal is much the same, I just need to apply it to the mini
Last Edit: Jun 8, 2019 16:04:12 GMT by adi
I saw this on Jay Leno - is that the one you're talking about (it's pretty bad@ss)
adi
Yea that's the one
johnthesparky
Club RR Member Number: 6
There are better qualified people to answer your question (and this may not be correct), but from reading other questions answered. If you alter the chassis or monocoque in any way it would need IVA. So I suppose it is possible to build something without needing to modify the chassis (search for medusa on here, which is twin engines and built on a taxi chassis) you would need to pick the chassis very carefully to avoid that. I suspect at the very least you’d need to strengthen the rear monocoque on those vehicles and probably modify the rear suspension which I think would mean IVA as well, as you may get away with the suspension on points, but it’s chassis mods too
The place to ask the IVA question is in ‘the legal bit’ in the build section
froggy
These type of builds always bug me as the end results are rarely worth the effort . Putting legalities aside the actual driving experience is always compromised by the amount of time you spend worrying you’ve selected both gears and managing traction as the rear motor pushes the front up making it easier to spin up . I ran a twin bike engined car for a while and tbh it was a pain in the rear to live with . Many years back I did a track day and followed a twin engined golf around donnington which was chaotic to say the least and cooked its braked after a few laps . Sort of works in a straight line but two motors without electronic management linking the two is pretty much a fairground ride
I have nothing usefull to add other than and
adi
But there's no denying it would be silly fast and a massive laugh no?
I have nothing usefull to add other than and The mini (twini?) kind of proves the case against, one of these nearly killed John Cooper IIRC? Would love the twini moke though!
Last Edit: Jun 9, 2019 2:08:25 GMT by mr2fc
The twinny Mini always gets blamed of being an undriveable car. And the John Cooper crash ( which did almost kill him ) is always the proof. It was a balljoint that failed. As far as I know, the car being twin engined had nothing to do with it. Seems like these things can take on a life of their own. Same with John Parry-Thomas' crash of Babs. People have been avoiding chain drives, because the story goes he was partially decapitated by one of chains on Babs. It has been dispelled, but the story wont die... Volkswagen built a couple of Twinny Golfs (for Pikes Peak I believe ), but I don't know how successful they were. I'd love to build a twinny. A modern Cooper would be a natural choice, because of the Twinny Mini's of the past. But a Modern Fiat 500 Abarth would be too, because if it is going to be called a 500 there should at least be an engine in the back. I wouldn't expect it to be easy to iron out the kinks, but I bet it would be a lot of fun...
Things I'd worry about ( besides the obvious ones, like throttle and shifting linkages ) would be getting the rollcenters right ( I bet sticking a second FWD unit complete with struts in the back wouldn't get them where you'd want them), and springrates front & rear, as well as shock valving.
I bet those things would make a big difference...
I've seen a Twinny Moke in a museum once, and the way the shifing linkages were coupled was really simple. I'd worry about the accuracy of that too. I think I wouldn't run separate linkages from the front and rear engines to a central shifter, but link the gearboxes with a linkage ( so you can accurately control the movement, even when the engine torque and braking moves and rotates them. And the adjustabillity), and run a 2nd linkage off that to the actual shifter.
Accurate smooth synched throttle linkages would be crucial too. If one lags behind, you have instant difference in front rear torque...
If after sorting all of that out it's still unruly, I 'd see if it would be possible to maybe adapt a aftermarket traction control unit ( or two ) to keep the RPM's within a certain percentage of eachother...
How do you expect rpm to differ between engines while driving? Not possible unless wheelspin.
The owner of squadra-tuning here in the Netherlands build an alfa gtv 916 with twin v6. 3.0 in front and 3.2 in the rear. Drives perfect.
Was a popular thing to do in AutoX a while back. All were vauxhall I think. Easy to bring gear linkage forward from them was the reason. One mod they did was make the rear engine run a couple of hundred revs faster so that it was “boss”. Might not be so good on hard surface? Sounds like a good project though. Cant see how you would get away with not testing it as the shell will need a fair bit of cutting.
adi
My biggest fear after all that work is that it wouldn't be allowed on the road.
Where's the guy with the twinny volvo T5 at??
MaxN
Jun 10, 2019 12:09:09 GMT
what about 2 paddle shift autos, you could easily mechanically link the paddles, leave the 2 gear selectors which would allow you to run one in N the other in D then switch to manual and use both.
Most are also drive by wire so for the throttles use 2 potentiometers with a bias linkage which allows you to change the front / rear balance like you would brakes.
Last Edit: Jun 10, 2019 12:09:48 GMT by kevins
adi
Jun 10, 2019 16:53:28 GMT
Most are also drive by wire so for the throttles use 2 potentiometers with a bias linkage which allows you to change the front / rear balance like you would brakes. It would be DBW and I'd already thought about that. Seems to be that it works better if the rear engine is "ahead" of the front
Last Edit: Jun 10, 2019 16:54:06 GMT by adi
Jun 10, 2019 21:12:58 GMT
Daz VRBANANA built a twin 20vt corrado, using a 6 point cage and 2 subframes, loads of work and expensive. in reality you can get more than enough welly from a turbo VR engine. Alternatively people have fitted full S4 running gear of TTv6 and V8 permutations.
Jun 12, 2019 21:27:16 GMT
I might be wrong, but I don't think you can run a twin engined thing on UK roads. Seem to remember something like a Scrapheap Challenge type program had a taxi or an ice cream van with two rover v8 engines. Had to take off a propshaft to be on the road. Was a long time ago mind, so rules might have changed.
