Of course the holy grail for handling would be to have a car with 50:50 weight distribution front and rear, and as little overall weight as possible, but sometimes these two goals can be at conflict with each other.
Take for example a car which has a 60:40 weight distribution front to rear (thats more weight on the front), and you have the option to remove the rear bumper or fit a GRP tailgate. This would have the effect of reducing overall weight - a good thing, but making the weight balance even worse - a bad thing.
So, my question is, which criteria would you chase hardest? Weight distribution or weight reduction?
My feeling is it's at it's worst in light front wheel drive cars, but a lighter tailgate could be offset with a lighter bonnet? Moving the battery back might help compensate for plastic windows (their weight saving would be at the back) and there's sometimes grp front wings about
Does surprise me when I see boot-mounted batteries that would be maybe a foot lower down if they were tucked behind the passenger seat
To actually answer your question (!) I guess it depends if you want to go roundyroundy or just in a straight line?
To actually answer your question (!) I guess it depends if you want to go roundyroundy or just in a straight line? In my particular case, I'm more concerned with cornering, but I guess things are different for drag racers. It would be interesting to know peoples thoughts on both.
slater
Club RR Member Number: 78
Weight reduction effects more than just handling tho 😉. That should answer your question. If I told you putting a bag of cement in your boot would make your car faster would you belive me? I'm hoping not lol!
raumer
I think there are a couple of other factors involved.
The height of the centre of gravity being one of the most important (as mentioned with the battery above). Getting it as low as possible would be my starting point. I don't think a 50:50 weight distribution is ideal for all cars. Front wheel drive you probably want a bit more on the front for grip. And things like the 911, Imp, Davrian etc... have done very well with 40:60 weight distribution.
If it was a race car I'd go for getting as much weight out as possible and then look at the distribution and how it handles. Can possibly adjust the suspension to help with balance. Getting a car that is balanced and you trust in the corners is probably most important.
Ed
Mine: 1938 Scammell Pioneer R100, 1944 Scammell Pioneer SV2/S, 1959 Kraz 255b tractor unit, 1960 Unipower Industrial ballast tractor, 1960 88 Landrover Series 2 SWB, 1983 110 Landrover CSW
Look after: 1935 Scammell Rigid 6, 1951 Scammell Scarab, 1961 Landrover Prototype, 1985 Landrover 110
Weight reduction effects more than just handling tho 😉. That should answer your question. If I told you putting a bag of cement in your boot would make your car faster would you belive me? I'm hoping not lol! In drag racing, more weight over the rear wheels can equate to quicker 1/4 mile ETs, so the bag of cement can make you faster :-)
Weight reduction effects more than just handling tho 😉. That should answer your question. If I told you putting a bag of cement in your boot would make your car faster would you belive me? I'm hoping not lol! In drag racing, more weight over the rear wheels can equate to quicker 1/4 mile ETs, so the bag of cement can make you faster :-) This! We can get a Beetle to wheelie with 120bhp, but its unlikely to go around a corner that well. Everything taken off the front should be balanced with weight out of the back if possible - that's why my drag bug ran a relatively heavy battery in front of the front axle instead of behind the drivers seat. It balanced out the lack of spare wheel well and the tiny fuel tank.
Indeed!
I've sometimes found heavier cars quicker! Albeit, that is more down to the suspension improvements etc. over generations of cars.
My 944 Turbo for example had 300kg less than my E46 M3 and around 40BHP less with it running 290BHP before I sold it. The Escort RST was similar. Sub-1000kg, with 230BHP. Out of the three I know which was consistently the quickest around the track, and the most stable. 2 of those cars also have 50-50 weight distribution, but I know which was much friendlier on the limit, especially on the road.
That said, the Clio 172 gave all of them a run for the money. That was as quick as the Escort RST on a track IME and on the road too.
Last Edit: Jul 8, 2019 0:01:04 GMT by ChasR
MiataMark
Club RR Member Number: 29
Interesting, I recently had a chat to somebody who sets up cars from armoured Land Rovers to touring cars and he said the last thing he wanted was a 50/50 weight distribution. If you want a car than can change direction quickly then 50/50 probably isn't ideal.
Personally I'd prefer a well balanced and predictable car.
IIRC from my toy-car racing days, 50/50 is perfect for a perfect driver that never makes mistakes, but for mere mortals a 60/40 weight towards the back) makes it more predictable
79cord
Don't forget polar inertia 50/50 with most weight near the middle will change direction (& be more 'unstable') than 50/50 with weights at each end. Also removing weight is usually harder than moving it, but once removed more can always be added where you want/need it easily.
In drag racing, more weight over the rear wheels can equate to quicker 1/4 mile ETs, so the bag of cement can make you faster :-) This! We can get a Beetle to wheelie with 120bhp, but its unlikely to go around a corner that well. Everything taken off the front should be balanced with weight out of the back if possible - that's why my drag bug ran a relatively heavy battery in front of the front axle instead of behind the drivers seat. It balanced out the lack of spare wheel well and the tiny fuel tank. Agreed, weight distribution is important. Wheelies just slow you down so. in this case, extra weight at the front will make you faster :-) I disagree, however, with your statement that weight removed from the front should be balanced with weight from the rear. My replacement engine is a lot heavier than the original so removing weight from the front has been a priority. Every car build is different so there are very few hard and fast rules that apply to all cars.
A racer I know used to do just that with his Porsche 996 cars when a driver of theirs lost alot of weight. Enough weight to now be under the mandatory weight limit. However, he was also able to place the balast to make up the difference wherever he wanted .
longman
Club RR Member Number: 3
Weight reduction and corner weighting makes a load of difference, my 911 is always going to be rear heavy so for my car removing weight from up high and at the rear was more important than from the front , after the weight removal getting the suspension/ride height/corner weighting tuned has made a huge difference in how the car behaves, its well worth getting it done properly
Paul 98 500 SL 86 911 Carrera/sold 23 Octavia Phev
Jul 15, 2019 17:09:22 GMT
Came here to mention polar moment of inertia as the third (or fourth with CoG height) piece of the puzzle.
From what I understand a 42-44% front produces the quickest car around a track as that's the ratio F1 cars hovered around before it was mandated. More traction coming out of corners, and more weight over the rear when you dive on the brakes and it all shifts forwards meaning they can split the braking F/R better.
As for what's more important weight vs distribution vs polar moment vs CoG height vs cross-weight I'm not sure. I expect it's a bit of a moving feast between all of them which isn't overly helpful.
One approach would be to pick an F/R percentage you want to aim for and then reduce weight staying within a percent or two of that goal, redistributing as much stuff as possible to be lower down, further inboard and evenly split left to right as possible.
Personally, I suspect polar moment of inertia and CoG height to have a greater impact on turn-in and twisty tight corners, and distribution to have more of an effect on sweepers (it affects which wheels will let go first, and how early they do compared to the other end).
CoG height also has an effect on springing as the higher it is the more a car dives and squats under braking and acceleration, meaning you need stiffer springs to control weight transfer which give less traction.
Overall weight will affect everything, but probably more as a scaling factor on how bad the other imbalances are. For instance if you have a 1000kg 60/40 car it's going to push in long sweepers, but if you have a 2000kg car it's going to push a lot more/sooner.
I expect someone fantastically clever could come up with a physics model for all of those variables and let you play around with what affects stuff more at different points, but that's not me!
May 16, 2022 14:51:58 GMT
When I tell people how I check my f500’s weight, they usually laugh at me. Last year I got concerned about the front-to-rear weight ratio, so I decided to buy professional Proform scales for $1000. Then, I looked at my electronic bathroom scale that I had bought at vont.com for $25. I bought 3 more of those. Now I lift each corner of f500 with a crank and shove each of the 4 scales under a wheel. Each scale can take a maximum of 400lb, so this method would work even for heavier cars.
Last Edit: May 16, 2022 14:52:25 GMT by siyar
May 17, 2022 21:42:41 GMT
If you are trying to corner faster, then would down force also be something to consider? Extra spoilers might make you slower on the straights but could more than make up for it in bends.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
If you are trying to corner faster, then would down force also be something to consider? Extra spoilers might make you slower on the straights but could more than make up for it in bends. Indeed. This has helped two folks I know. One of which is our very own @pinderwagon on here. His Golf is pretty quick with the times to back it up.
