ferny
Club RR Member Number: 13
Post gathering tinkering.ferny
@ferny
Club Retro Rides Member 13
Aug 19, 2019 10:18:59 GMT
Seems a few cars needed some work during the gathering, sadly. 😪
What's the progress? My steering column has just been removed to show lots of wear - not caused by the weekend but the hill showed it was time to investigate fully. Thankfully the rack seems ok.
Aug 19, 2019 16:39:36 GMT
Luckyseven pointed out at the show that I've only got one brake light, but that's not news to me. Thought it was more important to have brakes that work than brake lights... Still got to work out why fuses melt when I turn the headlights on though.
luckyseven
Club RR Member Number: 45
Post gathering tinkering.luckyseven
@luckyseven
Club Retro Rides Member 45
Aug 19, 2019 16:41:15 GMT
I did also point out that it's an improvement over the way morning started when you had no brakes, full stop
One of my indicators has filled up with water, does that count?
Aug 19, 2019 19:44:46 GMT
I did also point out that it's an improvement over the way morning started when you had no brakes, full stop One of my indicators has filled up with water, does that count? That is true. What I don't think I said was that I started Saturday's task with a LHD master cylinder... If you've got water in your indicator, put in a little plastic goldfish. I've always wanted to see that!
Post gathering tinkering.johnthesparky
@johnthesparky
Club Retro Rides Member 6
Aug 19, 2019 19:47:47 GMT
We did turn up with some finishing jobs from our Friday night engine removal and refit and we came home with a huge list of things that need fixing; Better crankcase breathing Have another check of the flywheel oil seal (been given a tool to fit it) Alternator needs lining up Need to sort a new alternator belt Drill the bellhousing Exhaust gasket leaks Fit a rev limiter! Fit the autometer tacho because it likes to rev now Smaller profile back tyres But if we hadn’t have turned up with it we’d have been chasing our tails for weeks and weeks, so it’s really good to have our list And then back to our original list... Sort the torque bar mounts Fit the seats Fabricate a wiring box for the dash Sort the flyscreen and upper screen I’m sure there is more, but that’ll do for a week or two
@johnthesparky
Aug 19, 2019 19:49:29 GMT
Luckyseven pointed out at the show that I've only got one brake light, but that's not news to me. Thought it was more important to have brakes that work than brake lights... Still got to work out why fuses melt when I turn the headlights on though. What size fuses? My money would be a chaffed wire
luckyseven
@luckyseven
Aug 19, 2019 19:53:29 GMT
We came home with a huge list of things that need fixing LISTI’m sure there is more, but that’ll do for a week or two You need to sort that fuel expansion problem too. It's not exactly convenient having to get a jamesd1972 to follow you around with a Land Rover to decant the leaking petrol into
@johnthesparky
Aug 19, 2019 20:09:22 GMT
We came home with a huge list of things that need fixing LISTI’m sure there is more, but that’ll do for a week or two You need to sort that fuel expansion problem too. It's not exactly convenient having to get a jamesd1972 to follow you around with a Land Rover to decant the leaking petrol into It’s not leaking!! It’s making petrol!! We’ve had two tankers turn up today to take away all the fuel That was a bit of a comedy of comedies though, We brimmed it with fuel on Thursday night, mainly because I wanted to see if the baffle foam made any difference... so got 30 litres in it (which was full full) Then noticed it had urinated it’s oil, so got towed home and forgot about it, it was cold on Friday... We parked it up on Saturday and decanted about 400ml when the sun hit the tank On Sunday it was parked filler cap down the slope and we decanted another bit under a litre I think (which luckily has just made me feel much better for not buying jamesd1972 a return cup of tea ) So the easy fix is don’t fill it with as much fuel, going to move a bit of baffle foam under the filler cap so I can see the level better.... If I guess we should fit a fuel gauge which would get rid of any range anxiety.... so should add that to the list instead!
Aug 19, 2019 20:49:03 GMT
Luckyseven pointed out at the show that I've only got one brake light, but that's not news to me. Thought it was more important to have brakes that work than brake lights... Still got to work out why fuses melt when I turn the headlights on though. What size fuses? My money would be a chaffed wire Er, the blue ones? That's all I had to hand last time, so chucked one of those in! I think most of the loom is toast, to be honest. I've got wires that stopped working years ago so they've got extras wrapped around the outside, stretched bits for the indicators, wires for the electronic ignition which aren't used any more, splices and bodged bits and all sorts. It's pretty much an electrical fire waiting to happen. I need to get a decent multimeter and a few rolls of wire, bite the bullet and just rip it all out and start again! I teach this stuff too!
The Doctor
Club RR Member Number: 48
Post gathering tinkering.The Doctor
@thedoctor
Club Retro Rides Member 48
My engine v1.0 didn't make it, v2.0 did, but it needs more work, as it's burning lots of oil. I've used 1,5l so far on this 1000km trip, with 300km to go Guess the bent valve from v1.0 has done more damage to the guide than I expected.
qwerty
Club RR Member Number: 52
Post gathering tinkering.qwerty
@qwerty
Club Retro Rides Member 52
Well my post gathering list is:
Clean out threads and replace wheel bolt on OSR hub OSR wheel bearing Sort the exhaust manifold so it doesn't rest on the ARB (The resonance was a killer) New Exhaust hanger Blue temp sensor
But least it made it there and back ok!
Tom
Aug 20, 2019 12:31:08 GMT
Seems a few cars needed some work during the gathering, sadly. 😪 What's the progress? My steering column has just been removed to show lots of wear - not caused by the weekend but the hill showed it was time to investigate fully. Thankfully the rack seems ok. Seen on the live feed that a vx220 hit the bank not far from the start, I think that will need a bit of paint
bstardchild
Club RR Member Number: 71
Post gathering tinkering.bstardchild
@bstardchild
Club Retro Rides Member 71
Aug 20, 2019 12:59:45 GMT
Seems a few cars needed some work during the gathering, sadly. 😪 What's the progress? My steering column has just been removed to show lots of wear - not caused by the weekend but the hill showed it was time to investigate fully. Thankfully the rack seems ok. Seen on the live feed that a vx220 hit the bank not far from the start, I think that will need a bit of paint Yeah he won the last run of the day in the tat auction - kinda regretting giving him a practice run so he knew where the track went
jamesd1972
Club RR Member Number: 40
Post gathering tinkering.jamesd1972
@jamesd1972
Club Retro Rides Member 40
Aug 20, 2019 14:22:32 GMT
Well our post 262 mile road trip list of additional things is well, er nothing. Despite being noisy slow and a bit uncomfortable everything functioned fine, even the nailed on tarp in heavy rain on the way back after the Morgan tour Monday. Still need to swap the engine out but the old one is still running OK for the time being so happy days. James PS johnthesparky thanks for the fuel it can offset the £70 worth we used getting there and back and you were welcome to the tea.
Last Edit: Aug 20, 2019 14:26:48 GMT by jamesd1972
