Ryannn
Hi all, Picked up a 1998 4.0 petrol Cherokee last night, it has a strange but I suspect simple problem.
Can drive fine for miles and miles without issue. But occasionally, when you give it the beans, it’ll splutter, cut out and won’t restart.
The only way to fix it is by giving the petrol tank a swift kick. Jump back in and away you go!
It feels like it must be a fuel pump/filter issue so just wondering if there’s anything else obvious I’m overlooking!
Checked the fuel lines? Years ago i had a problem the same, making more demands on the engine collapsed a dodgy bit of line, that was a mechanical pump tho’
Club RR Member Number: 160
Jeep Grand Cherokee Fuel Pump Fault?Rich
@foxmcintyre
Club Retro Rides Member 160
Sounds exactly like a pump fault. I’m not sure where the hp pump is on a grand, but if thumping the tank gets it going again then I think you are in the right area.
squonk
Is the fuel filler vent blocked?
Ryannn
Sounds exactly like a pump fault. I’m not sure where the hp pump is on a grand, but if thumping the tank gets it going again then I think you are in the right area. It’s in the top of the tank... so you have to take it out!
Ryannn
Is the fuel filler vent blocked? No idea, what’s the best way to check?
squonk
When the fault happens remove the fuel cap. You may hear a rush of air as you remove it. Then try starting it up. If it starts its likely that as fuel is drawn from the tank a vacuum is created in the tank to the point where the pump isn't powerfull enough to overcome the vacuum.
They've not been kind enough at jeep to put an access hatch above it in the floor have they?
Ryannn
They've not been kind enough at jeep to put an access hatch above it in the floor have they? Lol nope!
