ferny
Club RR Member Number: 13
Braking strangeness ferny
@ferny
Club Retro Rides Member 13
Triumph Herald single circuit system. MX5 turbo engine. Off-the-shelf generic servo.
Before Christmas I was taking a spirited drive through an area with lots of american traffic circles and found myself with very soft brakes. Normally they're nice and firm.
I've been away climbing Kilimanjaro (yes, I'm blowing my own trumpet) and decided to look at them today. All was fine and firm. Until I came into a roundabout and they were soft again.
Any ideas? I originally used the Mazda non-return valve and it didn't work - can't remember why - so it currently doesn't have one fitted. I've tested with the vacuum hose removed and it feels the same. The brakes have been fine since the servo was fitted 6 months (?) ago.
Is it possible to pump the pedal up and get it firm again? Ooerrr!
have you not just boiled the fluid?
get some ate200 and bleed the whole lot...
sonus
Common problem on TVRs that use Herald uprights. Scary until you know to double pump the brakes before panicking 😅
Phil H
Club RR Member Number: 133
Braking strangeness Phil H
@philhoward
Club Retro Rides Member 133
Common problem on TVRs that use Herald uprights. Scary until you know to double pump the brakes before panicking 😅 Hence why I mentioned it - have experienced it on cars with the “big” Triumph versions too 😂
even without knowing the intricacies of the hubs I'd suggest pad knock back too!
Check wheel bearings first. Given Triumph's weird budget arrangement at the back you should check those too.
Nick
ferny
@ferny
Deffo not pad knock. I've had it in the past and pressing the pedal doesn't return the brakes. The only thing which fixed them was leaving the car stationary. For the same reason it can't be air or boiled fluid. Rear brakes should be fine as I replaced the adjusters the other week and again the brakes felt perfect after left standing.
Thinking about it, I suspect master cylinder seals. I'll report back when I have time to strip it all down.
ferny
@ferny
Jan 10, 2020 18:00:50 GMT
Quick update for future searches.
Just replaced the brake master cylinder and the brakes are now firm and how they should be. I haven't stripped the original master cylinder for damages reports, but it appears to have fixed it.... so far.
Nice 30 min fix. 🙂
