Right, I want to check the timing on my Capri 2.0 to as it runs rough (although i think it might be down the the Carb mixture, the plugs are black ) . I only have a Gunsons static timing light but, can't find much info on it. I'm guessing the thicker connection goes on the spark plug and the thinner longer connection goes on the number 1 spark plug HT lead ?
It might not even work as i picked it up for £1 but, if it does that would be useful. I'd just like to know the timing is in before i start messing too much.
Also, does anyone know if having an electronic ignition changes much with the timing marks? I've added a photo of the distributor and all i'm getting is Mazda parts
