OGDB
Hello Once again. I am in need of some advice, guidance and just a nudge in the right direction in general. One of my Retros seems to be getting a bit hotter than it should. I've noticed this a few times in its most recent use and I am all too aware of things not getting too hot and causing further damage. The gauge that is fitted to the car does work but I do not have total faith in it and I am interested in hearing how you guys accurately monitor the temperature of the coolant in your older cars. In things with an ODB facility I use a device called a "Scan Gauge". Its a very interesting device that looks like a retro turbo timer. It can read selected functions like Engine temperature, Oil Pressure, Boost Pressure, Current MPG, ambient temps, Oil temp. Anything that is read by a sensor and relayed to the ECU can be displayed via this little gadget. They're interchangeable across vehicles and just a handy bit of kit, however unfortunately this is not compatible with my Porsche so I need to find an alternative. The last time I used the car was for an evening fishing trip back in may (once the lockdown restrictions on such activities was lifted slightly). Ambient temps were around the mid to upper 20's. The gauge crept up only at one time, and that was when I left the car idling so I could unlock and navigate numerous gates. The engine fan is kicking in but it would be nice to see an exact readout of temperatures, as I am sure there is something I could do to improve the cooling characteristics of the car if there was a problem. So my questions is... Are any of you using a more advanced that standard gauge to monitor the temperature of your engine and if so what are you using, how do you find it and would you recommend it? Here is the car in question at B&Q.
Phil H
Club RR Member Number: 133
If your cooling fan is working and cycling, I think you're probably looking for a problem that doesn't exist.
Don't forget that most cars of the OBD era and newer have pseudo temperature gauges anyway - "middle of the gauge" could be plus/minus 10 or 15 degrees whereas your Porsche one is probably "old school" and will actually move when the temperature changes by a few degrees.
Last Edit: Jun 8, 2020 7:58:43 GMT by Phil H
gryphon
Club RR Member Number: 157
If I stop in traffic etc the needle in the 944 will regularly creep up to the hot end of the gauge. Fan comes on and brings it back down. Just normal behavior. Most of the time cruising leaves it around the middle of the gauge (now that I've plopped a new thermostat in there anyway!)
The ECU has a different sensor to the gauge, but as you say you can't get the data out of them. You should be able to check it's resistance and calculate temp from that if you want a one off check.
Last Edit: Jun 8, 2020 11:06:31 GMT by gryphon
When I was having cooling issues with the Capri I was a bit obsessed with the temperature gauge/seeing if I could monitor things a bit better. I do have an electric fan connected to a temperature probe to activate the electric fan. I was going to run a light to the dash to confirm it was working, etc...
Once i sorted the root cause out (It combination of a few things..mainly me fitting the thermostat the wrong way around in the housing!) it behaves no matter the temp outside, and I just forget about it.
Last Edit: Jun 8, 2020 12:20:04 GMT by winchman
Hi, Virtually all dash temperature gauges, in fact all dash gauges, are not precision instruments. You need a bourdon tube temp gauge for that but then you need to get it into the water circuit. Time with the vehicle and its gauge will tell you when there is and isn't a problem, so as said don't over think it.
Colin
Are you talking about your 944?
If so, ensure the following is the case: -The gauge movements are smooth and stable -It doesn't randomly shoot up and pin itself to the top.
If that's the case I'd say the following. A 944 gauge isn't damped so it will move around like an older car would. Not many cars after that don't have damped gauges. it will go up to the last white mark before the red zone prior to the fans cutting in. It should come down quick however at this time of year and at this temperature. I'm surprised my M3 also has a semi-undamped gauge TBH! I will however say one thing.
If at this temperature in a 944, it takes more than 1 minute for your fan to go off and the fan operation seems fine, your problem will be one of two things -Iffy Thermostat -Poor radiator.
My rad in my 944 S2 seem fine visually. It wasn't massively corroded. However, the specialist who changed it noted the above and having raced many of them, knew the signs of it being bad. TBH I should have seen the signs then: -Rad water was black ; it obviously had seen Radweld -Fans would only cut out after 30 seconds in cold weather. -Many of the heater hoses and other hoses were swollen.
There was a much much bigger clue. The engine was knocking like mental:
In short, due to an overheating problem, my 944 S2 saw 3 engines in its life. The last owner prior to me changed the engine. I then changed the engine after the 2nd engine went, and actually dealt with the root cause. The Long version?
-Heater matrix had been leaking, as had the rad at some point. Owner of 10 years put Radweld in. -Rad's efficiency went down, I suspect it killed the engine (read on) -Engine was knocking like above. A bad tappet can sound like that -An idiot bought the car (me). £1.8k for an S2 back in 2010 seemed OK mind you, and low at the price point> -I took the car to a couple of garages. Only one diagnosed the cause ; a Seized piston due to insuffient clearances. Cited cause either low oil or overheating. The bore was toast. That noise in that video is piston slap -I drove the car until I found another engine. S2 engines then were between £800-1.5k depending on patience -New engine fitted. Specialist noted and gave many notes on the car having a compromised cooling system as I advised. They advised I changed it prior to Spring arriving. Then it became apparent it was most likely a poor cooling system which had killed 2 engines prior to me buying the car.
On almost every car I have changed a rad on, even with regular coolant changes, I've always noticed a difference in the cooling temps. It's an item I now try not to go cheap on. I can appreciate 944 rads are not cheap anymore however.
But if your rad etc. is working OK as I've advised above, you're probably OK.
Last Edit: Jun 8, 2020 23:00:54 GMT by ChasR
drseg
hand held laser temperature tools available from many sources mine was from a modelling shop with a nitro rc car if it gets too hot its running weak, but used it on fellow club members kit he thought was overheating pointed it at various places when it was in red and it was reading 75 c exactly same as a very similar vehicle with same engine, was sender gauge mismatch, took gauge apart and bent it a bit, dead scientific like. paid about £25 and checked it with a £400 version and was pretty much same
Last Edit: Jun 9, 2020 1:03:54 GMT by drseg
