nigxl
Were off again. Finally bought the car I viewed maybe 6 years ago. Owned one in the early nineties and they were few and far between then. Parts were not available then, who knows what's available 30 years on???
nigxl
Nice. I was watching that on the Bay of E.
nigxl
Oct 10, 2020 14:44:00 GMT
Thanks It's not without issues however. Looks like one or both of the head gaskets have gone. Luckily they are available.
nigxl
Oct 16, 2020 19:53:12 GMT
Decided to lift the engine out and have a look how bad it is.
May as well do a full engine rebuild with new everything as it's such a rare car. Got a couple of mates who are really good on the mig so they have just become my new best friends. Think this is going to be a total strip and resto, watch this space.
Oct 16, 2020 22:12:09 GMT
If you’re stripping it right down then you may as well go for WRX engine swap perhaps? Look well with some wide arches and Gold wheels. Picture for inspiration.
nigxl
If you’re stripping it right down then you may as well go for WRX engine swap perhaps? Look well with some wide arches and Gold wheels. Picture for inspiration. That may well be an option I'll get it out soon hopefully when time allows
nigxl
So I decided to pull the engine and found the problem as soon as I'd taken the cam towers off. It had decided to spit out one of the freeze plugs in the head allowing the water to mix with the oil.
nigxl
Back in and waiting for water pump and seals to arrive so I can do a pressure test.
Always loved these things. Shame they are so rare now, good work on the rescue though.
I'll be following keenly that's for sure. Love an XT, there's just so much tech packed into them, I'm sure I read somewhere they have adaptive steering that lessens the amount of turns lock to lock depending on speed and steering input, not to mention the lift suspension. I have been searching the internet and forums high and low for these over the past few months and think I have finally exhausted the possibilities of finding more - the numbers on how many left.com appear to be close to accurate, I don't think there are any left in the UK that have the digi dash, at least I haven't come across one with it. I really wish I was an infographic designer so I could find a way to display the information of those left in a really cool way.
nigxl
There may be another for sale soon. The guy I bought this one off has offered me another. I decided to decline his offer as I don't have the space or time for another.
nigxl
Parts are really becoming an issue for this car. I thought I'd found the correct water pump and brake caliper rebuild kit, how wrong I was. The pump is 6mm higher and the pistons don't have the receivers for the handbrake. Thanks Autodoc.
Last Edit: Nov 9, 2020 18:16:57 GMT by nigxl
Nov 10, 2020 12:54:24 GMT
It can be a nightmare getting the correct parts for older/rare Japanese stuff, especially when they have a non performance based identical model, part numbers seem to dilute within one another and there's usually several that have now been superseded by several more...
Amayama JP parts might come up trumps if you know the part numbers.
Is there an XT forum? I'm guessing they'll all be based abroad in particular OZ.
Don't like going to the dealer but they might be your only option or at least have some correct part numbers, if you don't have any, to go off.
If it were mine, which it obviously isn't. I'd bypass the engine rebuild and struggle with parts and see what's involved with a EJ swap. Plentiful, parts easily sourced, might mate up to your box and probably won't cost more time/money than rebuilding the engine what's in it?
nigxl
Nov 10, 2020 17:17:55 GMT
Dealer surprised me today. I can get a new pump for £20. Seems too cheap to me but we'll see what arrives. Ordered new caliper kits from them too, the original pistons have cleaned up fine. I fancy keeping this as original as I can, it's already had a suspension swap and has a broken spring so that's another job on the to do list. Yeah there is a big following in Oz and USA and parts are more readily available, the dealers don't normally post internationally though.
adam73bgt
Club RR Member Number: 58
Subaru XT Turbo Coupeadam73bgt
@adam73bgt
Club Retro Rides Member 58
Nov 13, 2020 12:16:32 GMT
Do like these, really funky looking
For parts, might be worth checking out Rock Auto in the US, can often get good prices on bits (which are a bit offset by the shipping..) but they're fairly quick on shipping if you use the FedEx option
Nov 13, 2020 18:03:35 GMT
+1 for rock auto. I get lots of bits from them and usually arrive within a week!
nigxl
Thanks guys Rock Auto it is then.
Ritchie
Club RR Member Number: 12
Subaru XT Turbo CoupeRitchie
@ritchie
Club Retro Rides Member 12
Nov 14, 2020 10:13:26 GMT
Rock auto can be amazingly cheap for some parts aswell, I've used them for Sub parts and have never had any problems.
nigxl
Nov 17, 2020 17:06:25 GMT
