I've set up a tank of citric acid for rust removal. I'm impressed so far, seems to be working well. First test pieces however are suffering a bit from flash rusting after.
I'm just thoroughly rinsing with clean water.
The plan is to epoxy prime after so I want to get a few bits done ready.
What's the best way to deal with the flash rusting? Is it worth setting up a bicarb tank to neutralise? Or is there anything I can spray on them after rinsing that won't be a pain when I come to prime?
Or, doninjust have to live with it and manually remove the flash rust before priming?
Thanks.
Thanks.
