Nov 16, 2020 15:24:49 GMT
On my Alfa diesel, 2 are stuck. I have cleaned out all dirt with a dental pick, made a nozzle for the vacuum and it’s all clean, they will not move. The internal diameter seems to be identical to the hole on the casing, I tried to lift them out with the pick, there is nothing to get under. Found a piece of dowel, put that in and whacked with a rubber mallet, trying to shock them loose, still nothing. Any suggestions ?
Bicycle x1 Alfa Giulietta (now wife's) Alfa 156 BMW 630i Honda rc36
Stuck injector sealsstealthstylz
@stealthstylz
Club Retro Rides Member 174
Nov 16, 2020 18:41:22 GMT
The proper tool is a small slide hammer with a easy out on the end.
Nov 16, 2020 18:52:48 GMT
Nov 16, 2020 19:31:07 GMT
There is not really a bad tar build up. Currently have a metal tube superglued on each seal, ya never know, picking up some proper picks tomorrow. I don’t think an easy-out would have anything to grip onto.
@stealthstylz
Nov 16, 2020 21:59:22 GMT
There is not really a bad tar build up. Currently have a metal tube superglued on each seal, ya never know, picking up some proper picks tomorrow. I don’t think an easy-out would have anything to grip onto. They wind into the copper washer. It's what we use at work it always gets them out even when they've been blowing for god knows how long and theres a lot of carbon buildup. www.amazon.co.uk/Laser-5450-Diesel-Injector-Puller/dp/B00FZJO2QE
Nov 16, 2020 22:09:58 GMT
I normally press a long flathead screwdriver down onto one side of the seal, then a good sharp whack with a hammer will dislodge the seal.
Tried screwdriver and a whack. Nothing can wind into the washer, the internal diameter hole is exactly the same as the injector hole. 09.15 today, been and inspected actually wearing my glasses, the 2 stuck ones seem slightly different to the ones that came out with the injectors. As I know the previous owner paid to have work done that did not get done very well I suspect that 2 have been replaced, attempts have been made on 2 and then left.
Nov 17, 2020 21:29:14 GMT
Have a look on here.....
at about 2' 55
Nick
