tofufi
South West
Nov 28, 2020 14:43:34 GMT
Hi folks, I've recently turbocharged my MK1 mx5. At the moment it has a nasty cone filter. I'd like to replace it with an OE airbox from something - but it'll need to be something big and flat. Anyone have any thoughts what might fit in this space?
Club RR Member Number: 160
Cars with flat airboxesRich
@foxmcintyre
Club Retro Rides Member 160
Nov 28, 2020 15:06:16 GMT
Nothing wrong with a decent quality CDA type filter if you can fit one in the space. You want to be able to go to a walk around scrappy really but not exactly easy these days to find one or do it in this current climate. Trying to think of something that would work otherwise and can’t think of anything that isn’t a big obscure shaped specific lump.
Nov 28, 2020 16:12:39 GMT
80s bmw .
ballbagbagins
Club RR Member Number: 164
Cars with flat airboxesballbagbagins
@ballbagbagins
Club Retro Rides Member 164
Nov 28, 2020 17:55:33 GMT
Mk2 golf has a flat filter but the air box is more boxy rather than flat. Depends how much depth you have.
dragon
Nov 29, 2020 10:11:31 GMT
Grab some cardboard, tube and tape. Find a suitable sized air filter to fit a popular model that's cheap, that then gives you the benefit of accessing some think like a K and N version. Make a mock up and ask on here if someone can custom build one. Don't forget lollipop sticks to mock up the brackets.
lebowski
Hillman Avenger, Clan Clover
Nov 29, 2020 11:27:37 GMT
What does the original airbox look like? I use an MX5 filter in one of my cars (not the airbox though) and it looks about the same size as the space you have there.
goldnrust
West Midlands
Minimalist
Nov 29, 2020 15:10:15 GMT
Another option is to keep the cone filter, but build a sort of air box that fills the space you highlighted, and seals against the bonnet. Was quite a popular way to get a good cold air feed for Mx5 turbos back when I was into them. Here’s a random google image result of the sort of thing I mean.
Nov 30, 2020 12:53:24 GMT
won't the standard mx5 one fit in there?
logicaluk
alx
Club RR Member Number: 21
Cars with flat airboxesalx
@alx
Club Retro Rides Member 21
It'll need to be something big and flat. Anyone have any thoughts what might fit in this space? As others have said a CDA would work well in that space But if you want the OEM vibe then maybe a Mk4 Golf air cleaner housing. Dunno if the dimensions would fit but they're pretty cheap. linkOr if you want to be a little bit alternative, a mower airbox. Again, no idea of dimensions. link Cheers AL.
tofufi
South West
Hi everyone, thanks for the suggestions Have contacted a few sellers for dimensions, and not a lot looks like a good option fit-wise. The standard filter - the back end sits where the turbo is now. If all else fails, I'll brush up on my CAD skills and get something 3d printed using a generic filter element
How about a Classic Mini late-model injection air filter housing? They are pretty flat although you'll need to figure out how to attach it. (generic pic from eBay)
Last Edit: Dec 9, 2020 21:05:24 GMT by mrbounce
