Jan 20, 2021 21:47:17 GMT
Hello all My first post here was only a week ago when I put up a wanted add for seats for the Sprint. I received a warm welcome and a suggestion that I should post more details on the car. So here it is. Its not an epic build thread by a long shot, its more of a catch up on a few years of tinkering. I have had the car three years now and bought it as a part finished project; Painted, complete-ish, stripped interior, non runner, tatty. It had sat unloved and unwanted for a couple of years. But the paint looked presentable in the correct cellulose Russet Brown, and all in all it looked to be a nice solid little project. I wasn`t looking for a full on resto at that point having just moved house and had (still have) loads to do on that. It looked like it fitted the bill, so I took the plunge. It turned up on the back of a truck and was duly tucked up in the garage. I basically set about it, working through everything to make it as solid, presentable, and hopefully reliable as possible! I`m not looking for a show car, more of a; retro, tidy, reliable driver. It was clear that the car needed a clutch and prop centre bearing so the gearbox and prop were duly removed, and fettled. I found that the offside chassis leg was a bit crusty, so replaced the rear portion with a new leg from the Triumph Dolomite Club. I then went through the brakes and clutch hydraulics with all new hard lines, Goodridge hoses, and rebuilt both master and the clutch slave cylinders. One thing the Sprint has is a Load sensing valve fitted to adjust the brake pressure bias, which stops the rear brakes locking before the fronts, due to the puny front discs and rather larger rear drums from the TR4 /6. Again the TD club is good for parts. The clutch pedal needed the usual elongated hole welding up and a new fork , which I was chuffed to find nos from Mick Dolphin. Mick is another great source of parts for all Triumphs. If you need anything Triumph, google him. Those puny brakes mentioned earlier were duly replaced with a tracker jack conversion. This uses Ford callipers and a VW vented disc which gives better stopping power. Old New I then found a had a leaky fuel tank But was lucky enough to find a nos one A bit of a tidy of the tatty edges New screen seals and side window rubbers Refit the interior To stripe or not to stripe? To stripe of course..... Refurbed alloys Solid carb mounts coz the OG rubber ones were shot causing a massive air leak and rough running Loads of other stuff I`ve forgot but basically a couple of years of tinkering got the Sprint running and driving beautifully. Well, it got me to the MOT station without breaking down! And, shock horror passed with flying colours. I was chuffed, even if it didn't need an MOT in the first place. So, I managed to put some miles on it before lockdown scuppered us all. But by no means enough miles. I cant wait till all this sh1t is over and we can get back out there once again, as I`m sure you will all agree. I`ve got some improvements to make along the way so I`ll update this as I go. One of the first jobs on the list will be the front seats fresh&minty put me on to. If you're reading this, cheers again for that. The dolly seats are like sitting on a bag of used nappies, so the seats will be a welcome addition. I`ve got a retro stereo install planned too, along with some poly bush work, engine mounts, rack mounts, winter wheels, blah blah blah
Jan 20, 2021 22:43:20 GMT
Nice👍
Jan 20, 2021 23:04:42 GMT
Beautiful car ... the British BMW 2002 or Alfa GTV. I had a TR4A years ago - drove it across America- so have a special appreciation of Triumphs. This one is a corker.
Best, John
bstardchild
Club RR Member Number: 71
Jan 20, 2021 23:36:59 GMT
Nice car - looks great for the age Fond memories of an inca yellow Dolly Sprint with a full length webasto sunroof, vinyl roof and a black inerior - great little car Not so fond memories of repeated head gasket failures in a short space of time I try to only think of the good memories
Very nice, I do like a Dolomite.
Hope the seats turn out okay!
Jan 21, 2021 20:01:06 GMT
Thanks for the kind words people. I’ve had no dramas with regards to reliability just yet. But there’s a good chance I have got all that to look forward to!? We will see. On the HG front, I’ve retorqued the head, and will do so religiously every 3000 miles. I’m told that helps. I’ve only done around 750 miles so far since getting it back on the road. I wanted it on the road for my 50th and made that easily but then covid scuppered my plans for getting out and about further.
I’d love to hear more about the TR4 trip across the states John! Sounds like a dream to me.
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Jan 21, 2021 20:10:10 GMT
Nice Dolly and looks great in russet brown, my dad had a 76 R Sprint in damson (complete with bonnet laurel) until it dissolved, his had inch and three quarter SUs and was bloody quick. Keep the updates coming, nice to see another BL car on here.
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Jan 21, 2021 20:20:03 GMT
Stunning , love that , nice work chap
raumer
Jan 21, 2021 20:54:18 GMT
Looks very nice. When you have the bugs out of it you could always have a go at the triumph club round britain run. A couple of our friends have done it and come back knackered but very happy.
Mine: 1938 Scammell Pioneer R100, 1944 Scammell Pioneer SV2/S, 1959 Kraz 255b tractor unit, 1960 Unipower Industrial ballast tractor, 1960 88 Landrover Series 2 SWB, 1983 110 Landrover CSW
Look after: 1935 Scammell Rigid 6, 1951 Scammell Scarab, 1961 Landrover Prototype, 1985 Landrover 110
Jan 21, 2021 21:00:36 GMT
That looks great - I even like the brown, definitely suits the car.
Jan 21, 2021 21:46:04 GMT
Thanks again for the kind words.
I do have every intention of doing the round Britain reliability run one year, or even better still the 10CR - 10 countries and a blast over the alps. But for now I’m just looking forward to better weather and driving the Sprint full stop. Anywhere will do.
Jan 21, 2021 21:54:14 GMT
Nice Dolly and looks great in russet brown, my dad had a 76 R Sprint in damson (complete with bonnet laurel) until it dissolved, his had inch and three quarter SUs and was bloody quick. Keep the updates coming, nice to see another BL car on here. All Sprints had twin, inch and three quarter, HS6 carbs as standard. Maybe your Dads Sprint had 2 inch HS8’s, off of a Jag or Rover? I have half an eye out for a pair of HS8’s, but would want a fast road cam to go with them!
Last Edit: Jan 21, 2021 21:58:04 GMT by adybish
Jan 21, 2021 23:51:23 GMT
I do love a Dolly Sprint. Passed up an opportunity to buy a stripped out GT6 mild hillclimb car with the 16v slant 4 swapped and I've been kicking myself ever since!
Ohh a dolly. Lovely colour brown. I had a plemento red one in the early 80’s VNJ 222S Paid £550 for it. I wanted to be like KITT and tried to do all the things he did lol I fcked the engine and that was the end of that lol I would love another but prices are creeping up now. Lovely motor tho fella.
Mk5 Cortina 1982 Nissan Sunny 1987 Audi A6 black edition ultra VW Transporter Kombi Suzuki B King Kawasaki ZX10R Honda max 125 Suzuki SB200 (1979)
Jan 22, 2021 10:38:58 GMT
Glad you posted a thread up, my first car was a 1977 inca yellow 1500HL with sprint wheels. Sadly I had neither the funds or the knowledge to maintain it so gave it away.
The reg number of yours seems really familiar - I'm going to go back through my old issues of Dolly Mixture to see if I can find it.
retrolegends
Jan 22, 2021 17:08:22 GMT
Nice Dolly and looks great in russet brown, my dad had a 76 R Sprint in damson (complete with bonnet laurel) until it dissolved, his had inch and three quarter SUs and was bloody quick. Keep the updates coming, nice to see another BL car on here. All Sprints had twin, inch and three quarter, HS6 carbs as standard. Maybe your Dads Sprint had 2 inch HS8’s, off of a Jag or Rover? I have half an eye out for a pair of HS8’s, but would want a fast road cam to go with them! Ah maybe they were 2 inch then, I know they were non standard, my brother used to borrow it and wheel spin off the drive just to annoy the old fella 😂
Jan 22, 2021 17:42:38 GMT
Dolomites are a bit of a double edged sword for me always loved them but working at a BL DEALER late seventies early eighties worked on my fare share of these.Nice car though.
adam73bgt
Club RR Member Number: 58
Jan 22, 2021 18:27:06 GMT
I love Dolly Sprints, they manage to have such a great exterior look from stock with the deep dish alloys and front spoiler, they just sit right I wanted one for my first car but couldn't afford it so ended up with an MGB GT Some nice period styled brown bucket seats, maybe with a plaid or tweed centre section would look great
Jan 22, 2021 19:35:10 GMT
Great work. I love a sprint. Car is a cracker.
shin2chin
Jan 22, 2021 19:45:16 GMT
That looks great in Brown, always had a soft spot for Sprints being a Cov boy.
