Roach
May 14, 2021 16:16:06 GMT
Can any of you lovely people tell me what this caliper is off of? It came as part of an empi disc brake kit for my beetle..... but I think one is faulty, and they don’t supply them separately. That’s a very long story cut super short.... but basically I have an undrivable beetle and a 3 week lead time for a new kit. So here is one of them, they are stamped L and R so they are handed... they have to be off something else.
penguin45
Still welding......
May 14, 2021 20:37:23 GMT
You may be out of luck. EMPI 22-2956B is only listed for Beetles. No further cross references.
Brake caliper identification fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
May 14, 2021 20:58:11 GMT
When you say “ they have to be off something else” do you mean you’re hoping that they also fit another car or do you mean you’ve bought them and they don’t fit?
Just wondering if they’re for a different year model beetle or other components have been swapped over on your car in the past?
Brake caliper identification Dez
@dez
Club Retro Rides Member 34
May 14, 2021 21:03:44 GMT
No beetle has single piston sliding calipers as standard. They’re usually a 2 piston design.
They could be a mild rehash on an existing caliper with specific part numbers. The fact they have empibcast into them doesn’t look favourable though. Bearing in mind they’re for solid discs, they look a *bit* like mk2/3/4 golf but without the handbrake mech. One of those would be cheap enough s/h to buy for comparison purposes.
Club RR Member Number: 160
Brake caliper identification Rich
@foxmcintyre
Club Retro Rides Member 160
May 14, 2021 22:30:18 GMT
Any ref. numbers on the pads? That may help narrow it down.
adam73bgt
Club RR Member Number: 58
Brake caliper identification adam73bgt
@adam73bgt
Club Retro Rides Member 58
May 14, 2021 23:09:02 GMT
That design of caliper was often used by TRW or Bosch but they're also made by a myriad of companies these days.
Cross referencing in a brake pad catalogue going off the brake pad shape/dimensions may get you close
What about it is faulty?
Brake caliper identification ChasR
@chasr
Club Retro Rides Member 170
They look bespoke.
I can’t think of many handbrake calipers which have that large a piston.
Can you measure the piston up on its diameter?
As Adam said, what is the problem?
Last Edit: May 15, 2021 7:09:10 GMT by ChasR
Look very much like the ones on the rear of my C4 A6, except they have a handbrake mech. Those has 57mm pistons.
Might be worth speaking to Bigg Red who can probably find you parts if not the whole thing.
Nick
Look a lot like the ones on the rear of my C4 A6, though those have a handbrake mech.
They have 57mm pistons.
Might be worth speaking to Bigg Red? They will probably be able provide parts, if not the whole thing.
Nick
Roach
May 15, 2021 16:07:50 GMT
I was supplied this kit fitted to the beam I purchased.
So I’m hoping it can be fixed without me having to put my hand in my pocket.
The problem is the piston won’t let off the disc when the brakes are applied, it only releases if you crack the bleed or physically prize the pads open.
Empi don’t supply the calipers separately apparently, and full kits are on back order.... hence I was hoping to find what they were from as a last resort fix.
May 15, 2021 17:29:44 GMT
Have you had a look on Vw heritage ? Looks like they sell individual EMPI ones.
May 15, 2021 17:45:23 GMT
I was supplied this kit fitted to the beam I purchased. So I’m hoping it can be fixed without me having to put my hand in my pocket. The problem is the piston won’t let off the disc when the brakes are applied, it only releases if you crack the bleed or physically prize the pads open. Empi don’t supply the calipers separately apparently, and full kits are on back order.... hence I was hoping to find what they were from as a last resort fix. Hi, That doesn't sound like a caliper problem, it sounds like a problem 'upstream'. Like a flexible hose that has partially collapsed and acting like a one way valve. Or it could be a problem at the master or servo. If it's one side then I would say it's a flexible hose. If it's both sides then master or servo. Colin
Roach
May 15, 2021 19:11:53 GMT
I was supplied this kit fitted to the beam I purchased. So I’m hoping it can be fixed without me having to put my hand in my pocket. The problem is the piston won’t let off the disc when the brakes are applied, it only releases if you crack the bleed or physically prize the pads open. Empi don’t supply the calipers separately apparently, and full kits are on back order.... hence I was hoping to find what they were from as a last resort fix. Hi, That doesn't sound like a caliper problem, it sounds like a problem 'upstream'. Like a flexible hose that has partially collapsed and acting like a one way valve. Or it could be a problem at the master or servo. If it's one side then I would say it's a flexible hose. If it's both sides then master or servo. Colin I’ve swapped the flexis from side to side and the problem remains. Brand new ATE master cylinder. And the pedal has been set correctly. just one side, the other side seems free(ish) but I’m putting that down to all brand new kit that isn’t yet worn in... but the near side binds badly, so much so the mile test run turned the disc blue.
@dez
May 15, 2021 19:28:06 GMT
Sounds like a drum brake master cyl on a Disc brake car.
Roach
May 15, 2021 20:07:13 GMT
Sounds like a drum brake master cyl on a Disc brake car. I thought that. But I have friends who run single circuit m/c’s with front discs and have no issues.
jpsmit
How old are the flexis?
Roach
squonk
May 16, 2021 11:08:26 GMT
A brake caliper is a simple device which consists purely of a chamber with a piston and a hole to let fluid in and out. There are no valves within the caliper to control the flow of fluid. The fact that your brakes apply and stick but release when the bleed screw is undone suggests that pressure is being held within the caliper. As there is nothing inside the caliper that can retain the pressure this points to a problem outside of the caliper. Something is not letting fluid return into the master cylinder reservoir. As has previosly been said, a hose colapse that makes it behave like a one way valve could cause this.
However, I am concerned that you imply the other brake is also dragging. Being new should not create this problem - the brakes should work perfectly as soon as fitted if they are correctly bled and set up. The fact that the other brake is dragging could well indicate a master cylinder problem and the other caliper isn't locking simply because there is a small amount of air in the system on that side (the air could compress enough to allow the caliper to partially release but still cause it to drag).
I'm 100% sure that there is nothing wrong with the caliper. The dragging of the other brake really does point to a master cylinder issue.
Last Edit: May 16, 2021 11:08:59 GMT by squonk
May 16, 2021 11:48:18 GMT
some Drum braked cars have a residual pressure valve in the system to hold pressure for a better pedal and the large springs in a drum brake will easily overcome the pressure. calipers wont.
is the master cylinder designed for drums or is there some sort of valve somewhere?
just a thought as i have come across this before on other vehicles with drum to disc conversions.
@chasr
May 16, 2021 13:18:28 GMT
Sounds like a drum brake master cyl on a Disc brake car. I thought that. But I have friends who run single circuit m/c’s with front discs and have no issues. They are different. Drum brakes have pressure valves IIRC in them, so you need a disc brake master to work with it. Otherwise, they will just keep binding on.
Last Edit: May 16, 2021 13:18:49 GMT by ChasR
