LowStandards
So, my new whip takes an ages to warm up and then when it is, if I go fast, it starts to cool again.
I'm guessing its a faulty stat and i'm gonna change it tonight, but I was just wondering if there's anything else that could cause this that I should be worried about???
Ta
I think you mean over-cooling.... Thermostat would be my first port of call.
LowStandards
I think you mean over-cooling.... Thermostat would be my first port of call. Err, thats what I put, i've in no way modified my post I reckons its gotta be the stat, hey its worth changing for the £7 it cost, shame its so damn dark wheen I get home...
Causes of OVERcooling - SORTEDRobinxr4i
@robinxr4i
Club Retro Rides Member 143
As seth says thermostat would be the most obvious culprit. Is it on the rather nice Celica in the pic below?
If the fan's stuck 'on', that'll do the trick nicely as well....
LowStandards
Nov 12, 2007 10:07:04 GMT
It is indeed the Celica, damn J cars with there massivly effcient radiators...
Fans not on, least if it is its whisper quiet
Nov 12, 2007 11:06:23 GMT
Check the stat, if it's ok then block off half the rad while the weather is cold
LowStandards
Nov 12, 2007 11:41:27 GMT
Check the stat, if it's ok then block off half the rad while the weather is cold You should bring out a book: "Fixing cars the 50's way, by Jonny69" ;D
Nov 12, 2007 19:25:10 GMT
Before I saw the car I was going to say that it could just be down to the cold weather (thinking old british car with a viscous van and a lump of card in front of the rad for the winter here ) When I saw it was a toyota I would say the stat. I remember the outer cage of the stat actually snapped on my AE86 when I was coming back from a rally at otterburn in the winter many moons ago and could not get the temp out of the blue on the way home so it ran with the 5th injector on all the way home and used loads of fuel. Not sure location of stat on these engines but on the 4AGE they are under the inlet and a bit of a pig to get to and you have to take car when it comes to bleeding as they were prone to air locking. If they air lock they revs used to climb over 1500 then drop to 800 all the time on idle.
LowStandards
I remember the outer cage of the stat actually snapped on my AE86 Ha, spot on! "There's ya problem mate"
