Jun 15, 2021 12:16:03 GMT
Colonelk
Club RR Member Number: 83
Jun 15, 2021 16:10:56 GMT
Thanks for featuring my car. Tis a silly thing, but I like it
Jun 15, 2021 16:48:20 GMT
Excellent! Had a look/chat at the Weekender and if it is silly, it’s wonderfully silly
Jun 15, 2021 18:40:36 GMT
Would the bigger pump you need happen to be the Zexel as fitted to my shape Delica's?
Colonelk
Jun 15, 2021 20:41:48 GMT
Would the bigger pump you need happen to be the Zexel as fitted to my shape Delica's? yeah I think the one I'm looking for is the one off a 4M40 engine (IIRC) 2.8 TD with the mechanical pump basically. I want the injectors also
Last Edit: Jun 15, 2021 20:42:01 GMT by Colonelk
Jun 15, 2021 21:21:50 GMT
Aye that's the one. Remind me closer to RRG and I'll bring a pump and injectors down for you.
skinnylew
Club RR Member Number: 11
Jun 15, 2021 22:22:52 GMT
Sounds immense and should shift somewhat with that amount of detail and time put into that set up. Just needs a ghetto blaster zip tied to the grill now.........
Colonelk
Jun 15, 2021 23:01:50 GMT
Aye that's the one. Remind me closer to RRG and I'll bring a pump and injectors down for you. You bloody legend
Colonelk
Jun 15, 2021 23:02:32 GMT
Sounds immense and should shift somewhat with that amount of detail and time put into that set up. Just needs a ghetto blaster zip tied to the grill now......... You just reminded me of an old plan...
I loved the look of this at the weekender although at the time I just thought it was lowered on shiny wheels.
I spotted the 6 studs but assumed it was just wheel adaptors.
I'd never have guessed the level of work that's gone into it under the bonnet.
I didn't spot the joystick gear knob either, pretty sure I had that joystick for the PC in about 1992.
Just goes to show how valuable these videos are when things are explained in demonstrations / discussions.
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K...
Club RR Member Number: 160
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K... 110% Colon Elk. Isn't it Colonelk, that's right, yeah?
It’s definitely Colon Elk. Some people have weird fetishes, but we don’t judge… fr€$h&m1nt¥ has just made me realise they must be the super thin 6 stud adapters I made years ago. I think one set went on andys record and these are the other set.
Sounds immense and should shift somewhat with that amount of detail and time put into that set up. Just needs a ghetto blaster zip tied to the grill now......... That was a great day
fr€$h&m1nt¥ has just made me realise they must be the super thin 6 stud adapters I made years ago. I think one set went on andys record and these are the other set. Korrekt
Colonelk
Jun 16, 2021 11:03:46 GMT
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K... Haha, it was supposed to be Colonel K of Dangermouse fame, but I didn't include the space or capitalise the K on various forums, which lead to many people thinking my name was colon elk. Thankfully Colon was mostly dropped save a few die hards, and now most people know me as Elk, including my entire work 🤣
Jun 16, 2021 13:00:31 GMT
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K... Haha, it was supposed to be Colonel K of Dangermouse fame, but I didn't include the space or capitalise the K on various forums, which lead to many people thinking my name was colon elk. Thankfully Colon was mostly dropped save a few die hards, and now most people know me as Elk, including my entire work 🤣 Thanks for clearing that up, thought that was the case - I obviously see past things like capitalisation! And they are 6 stud wheel adaptors after all rather than a wheel hub change due to the engine swap?
Colonelk
Jun 16, 2021 13:56:09 GMT
Haha, it was supposed to be Colonel K of Dangermouse fame, but I didn't include the space or capitalise the K on various forums, which lead to many people thinking my name was colon elk. Thankfully Colon was mostly dropped save a few die hards, and now most people know me as Elk, including my entire work 🤣 Thanks for clearing that up, thought that was the case - I obviously see past things like capitalisation! And they are 6 stud wheel adaptors after all rather than a wheel hub change due to the engine swap? Yup, 6 stud adaptors
Jun 26, 2021 19:44:30 GMT
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K... Haha, it was supposed to be Colonel K of Dangermouse fame, but I didn't include the space or capitalise the K on various forums, which lead to many people thinking my name was colon elk. Thankfully Colon was mostly dropped save a few die hards, and now most people know me as Elk, including my entire work 🤣 Forum names eh. Soooo many times I get called Eddy in pms or at gatherings. I've always read your name as colonel k. But now I see colon Alex.
andy88
Jun 27, 2021 22:43:26 GMT
PS So is it Colon Elk or Colonel K? I guess the Elk name was picked up due to a previous misunderstanding? I've always read it as Colonel K... Haha, it was supposed to be Colonel K of Dangermouse fame, but I didn't include the space or capitalise the K on various forums, which lead to many people thinking my name was colon elk. Thankfully Colon was mostly dropped save a few die hards, and now most people know me as Elk, including my entire work 🤣 Ah that explains it, thanks for clearing that up, I was confused by 'Elk 'after seeing you as ColonelK on Migweb years ago
