It is that time again! Head to www.retroridesgathering.com and you'll find a link for the track applications I'm sure bstardchild will be along in the not too distant future to answer questions you may have, although I know his August is lining up to be insanely busy. Plans are the same as previous years, Pre-98-ish, road going cars, you'll need a helmet (we'll have some for hire).
Jul 16, 2021 10:13:13 GMT
Thanks
boffer8
Club RR Member Number: 75
Jul 16, 2021 11:23:21 GMT
Awesome, Applied ;-)
Jul 16, 2021 17:29:00 GMT
Help!!
I applied but used my old forum name as I got locked out before and got confused about which account to use, then i went to edit the application with the correct info and had an error come up. My other username is Fantanya, can someone help fix this for me?
1991 Eunos Roadster 1.8 1996 Honda S-MX Lowdown 1996 Tamiya Honda S-MX Lowdown RC roadster_heaven on Insta
Jul 16, 2021 19:11:44 GMT
Help!! I applied but used my old forum name as I got locked out before and got confused about which account to use, then i went to edit the application with the correct info and had an error come up. My other username is Fantanya, can someone help fix this for me? We'll get the editing fixed over the weekend 😉
Help!! I applied but used my old forum name as I got locked out before and got confused about which account to use, then i went to edit the application with the correct info and had an error come up. My other username is Fantanya, can someone help fix this for me? We'll get the editing fixed over the weekend 😉 Thank you
Paul
Done! hairymel, reckon you’ll be applying?
hairymel
avatar by volksangyl
Club RR Member Number: 207
Jul 18, 2021 13:00:44 GMT
Done! hairymel, reckon you’ll be applying? i have. but shush
whats that burning smell?
oh curse word :-(
Jul 26, 2021 20:05:59 GMT
If I don't wreck on Saturday then I am down for hot laps. If I do wreck.. then be prepared for the slowest thing up the hill ever.... RACETRANSPORTER.
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
Jul 26, 2021 20:31:04 GMT
If I don't wreck on Saturday then I am down for hot laps. If I do wreck.. then be prepared for the slowest thing up the hill ever.... RACETRANSPORTER. Don’t threaten us with a good time
lemon
Gear head
Are there any noise regulations enforced? I can't seem to find any info on that...
Last Edit: Jul 27, 2021 8:54:15 GMT by lemon
More than it should be, but not as much as it could be
Jul 27, 2021 16:51:11 GMT
If I don't wreck on Saturday then I am down for hot laps. If I do wreck.. then be prepared for the slowest thing up the hill ever.... RACETRANSPORTER. Don’t threaten us with a good time You know how I like to party.
bstardchild
Club RR Member Number: 71
Are there any noise regulations enforced? I can't seem to find any info on that... We’ve run unsilenced ex F1 cars up the hill in the past not to mention other equally noisy cars and hill climb specials so no noise regs Does need an MOT mind (if not a guest car)
lemon
Gear head
Hi, thanks for the reply. The car is not currently MOT'd, but is MOT exempt, is that OK? Cheers, Drew Are there any noise regulations enforced? I can't seem to find any info on that... We’ve run unsilenced ex F1 cars up the hill in the past not to mention other equally noisy cars and hill climb specials so no noise regs Does need an MOT mind (if not a guest car)
bstardchild
Hi, thanks for the reply. The car is not currently MOT'd, but is MOT exempt, is that OK? Cheers, Drew - Exempt as in too old is fine - I should have put that as the acceptable exclusion - Exempt as in less than three years old not so much fine
bstardchild
Done! hairymel, reckon you’ll be applying? i have. but shush I have seen it - has it got power steering
Do you know when you will be doing the short list for the hill ? I'm super exited to know if i get a go or 6 !!! I had the best day last time
hairymel
i have. but shush I have seen it - has it got power steering Um no. No it hasn't. It also does not have the 'optional' heater I really need to crack on as I have only driven it round the yard at work once since it arrived😆
oh curse word :-(
When will we hear about the shortlist please? Ta
