mexicansteve
South West
Club RR Member Number: 31
Mercedes mb100 engine plate mexicansteve
@mexicansteve
Club Retro Rides Member 31
May 17, 2022 13:53:39 GMT
My google-fu is weak, can anyone either decipher or point me in the right direction to decipher the engine plate. I've added the other number as I just want to know what it means too. Thanks.
BeQuietandDrive
1989 Bedford Astra Van
May 17, 2022 15:05:14 GMT
The 6161410701 is likely the part number for the manifold casting.
Living vicariously through other people's projects!
Turbogeek is correct 616 141 07 01 is the part number for whatever part that it's cast into.
I can't do a Partslink search without a VIN, so PM if you like and I will see what I can find. Hopefully I can get the aggregate details for the engine as a sub assembly from the VIN. Looks like the M100 is on Partslink too..
Additional info for the anorak in you. May come in handy for others in the future: MB part numbers the first 3 digits indicate the model it applies to unless it's a part that applies to multiple models in which case they apply to the sub-assembly. IE parts beginning A 211 XXX XX XX will be specific to the W211 chassis E class. If it were a part specific to say the OM648 engine in one of those W211s it will begin A 648 XXX XX XX. (although if I were being pedantic, some parts may begin A613 XXX XX XX as the OM613 is the predecessor to the OM648)
The second set of numbers relate to the part location so in the number below 880 refers to the front bumper cover, the second to last two (if I recall correctly) indicate left - 01 or right 00 (where applicable) and variants so bumpers will have various combinations on modern cars especially as you will have with park assist (4 or 6 sensors), with headlamp washers, with AMG styling, 360 camera etc and all combinations available for those trim levels.
Supplementary numbers refer to colour so A 176 880 06 40 9999 is a front bumper for a 176 A-class, 9999 indicating that the part is supplied in primer. I'm yet to work out what the first of the four additional digits is for but the last three are the paint code for the outer body if the part is supplied in body colour (ie Jupiter red mirror cap for a A176 A-class ends 3589, 589 being the colour code)
VAG have a similar system which uses model, location, type and colour in that order.. I once rang my local TPS to check a part number and the guy guessed black textured NSR door moulding for a MK6 golf straight off the bat. Tom
mexicansteve
South West
@mexicansteve
May 18, 2022 10:53:43 GMT
Thanks for the many nerdy words 😁 Personally I find these plates a mystery!
BeQuietandDrive
May 20, 2022 20:54:03 GMT
VIN works! Good news is that full parts catalogue exists but is no longer updated. Most fasteners and consumables etc are available but body trim and large mechanical parts show NLA (can still get a windscreen and fitting kit with seals etc, badges, body to chassis bushes and washers and cylinder liners to name a few) Mercedes are pretty good at supplying OEM parts for their older cars so try them before you deal with overcharging muppets on flea bay... I managed to get a wing and all front bumper brackets and mouldings for a 1999 CLK320 in 5 working days for a customer. Shipped through their dealer network from germany so if they have anything you need you won't be waiting much longer than that I reckon..
Here's some info which may or may not make sense to you. It's much less than you would get for a modern. I was hoping for a build date and stuff but you could maybe get on to Mercedes in Deutschland with your order number and VIN asking if they have any more info??
Sales term MB 100 D Order ID 5222900123 Paint Code 3626 (rubinrot 88) Engine 61696310161710 (OM616) Transmission 71831110111521 (718.311 transmission if you're googling) Body 33256510218231 Steering 76645110 Other Body: 3
Model options list: (cut and paste) Type code Description 04105404 FIRST AID BOX 04105504 HAZARD WARNING TRIANGLE 04110903 FOGLAMP - INSTALLATION IN FRONT BUMPER; AMBER DIFFUSER WHITE 04111002 HEADLAMP LEVELING SYSTEM 04111301 STEERING - HYDRAULIC POWER STEERING 04111452 FLOOR COVERING - PERFORATED WOOD FLOOR, FOR SAFETY BELT ANCHORAGE 04111603 HEADLINER 04112132 SEATS - DOUBLE OCCUPANCY SEAT; FABRIC VERSION 04113102 RADIO INSTALLATION - PRE-EQUIPMENT FOR SUBSEQUENT INSTALLATION OF RADIO 04113203 HEADLAMP - WHITE BULB,WITH LIGHT RANGE REGULATOR 04113414 SEAT BELT - FOR ONE DOUBLE OCCUPANCY SEAT BENCH AND WOOD FLOOR 04114001 TORSION BAR - HIGH-LOAD TORSION BAR 04114811 INTERIOR TRIMMING, HARD FIBER - LEFT AND RIGHT SIDE PANELS,REAR 04120414 RUBBER MATS - FOR DELIVERY VAN CAB FLOOR AND STATION WAGON WITH WOOD FLOOR 04120415 RUBBER MATS - NO SPARE PARTS INVOLVED (ADDITIONAL WORK) 04121351 04122101 TRAILER COUPLING - FOR BOX TYPE DELIVERY VAN,STATION WAGONS I & II,LONG & SHORT VERSIONS; BUS & PLATFORM VEHICLE,LONG VERSION 04122301 ANTINOISE CAPSULE - TROPICAL VERSION 04122902 TORSION BAR,FRONT - H.D. STABILIZER 04123901 GUIDE SIGNS - USED FOR TRAILER COUPLING 04126801 SPEEDOMETER WITH TRIP ODOMETER READING IN KILOMETERS 04127001 OUTSIDE REARVIEW MIRROR-ELECTRICAL SYSTEM - FOR HEATED OUTSIDE REARVIEW MIRROR 04127101 BRIGHTNESS CONTROL,INSTRUMENT LIGHTING 04127702 LOCK - W/ANTI-CHILD DEVICE IN SLIDING SIDE DOOR 04127801 OUTSIDE REARVIEW MIRROR - HEATED REARVIEW MIRROR 04128208 REAR END DOOR HINGE,270 DEGS. 04128610 ELECTRICAL EQUIPMENT USED FOR SERVICE WITH TRAILER - LONG WHEELBASE; 7-POLE PLUG SOCKET 04160205 OIL PAN - FOR VEHICLES WITH ADDITIONAL UNITS 04160605 CRANKSHAFT PULLEY 04160817 INJECTION PUMP - SEE STANDARD MICROFICHE 04163903 ENGINE PARTS USED WITH POWER STEERING 04164801 ABGASREINIGUNG
mexicansteve
South West
@mexicansteve
May 21, 2022 13:32:10 GMT
Thanks so much. Is the parts list available to anyone? Actually may need the windscreen kit at some point.
BeQuietandDrive
May 21, 2022 18:08:27 GMT
No, the information above is from an OEM proxy parts catalogue we use at work so all the info is as it appears in mercedes parts catalogue including diagrams but you have to buy a subscription and can't go round handing out my company log in unfortunately! You can use a demo version with no vin look up here: www.partslink24.comHit the subscribe button at the top to see the prices, little over a tenner for a full day's access. Just screen grab to your hearts content!
mexicansteve
South West
@mexicansteve
May 22, 2022 13:28:54 GMT
Sweet, that'll work nicely. Thanks again for your help
BeQuietandDrive
