Hi
I have a standard 3.5 rover v8 SD1, fitted with a holley 4160 390cfm.
I've found on google that Holley advise the fuel pressure to be between 5 - 7PSI, which i've had a look on eBay and found two Facet Red Top cube pumps and one of them is (Model 40106) rated 4 - 7PSI and then the other is (Model 40107) rated 7 - 10PSI.
Would i need the pump rated 7 - 10PSI then regulate it down to the recommended 5 - 7PSI?
I already have a Filter King fitted.
Any help will be much appreciated.
Thanks
Thanks
