Paul Y
Morning all, As I am a Neanderthal I managed to break the 'shroud' that goes around the top of Woody's steering column. It would appear that this part is not available as a reproduction so looking for any suggestions on what I could use. This is the part in question. Bit frustrating but I am hoping one of you clever chaps will go 'Ah, That looks exactly like....' Appreciate your help. P.
awoo
No ideas on what else it looks like but if you have the other bit it surely could be repaired?
Or even a 3D printed replica made
ems1
Club RR Member Number: 5
Jul 30, 2022 12:28:45 GMT
If it doesn't need the curve you could use a piece of alloy or stainless pipe. Another possibility is an exhaust reducer. Alternatively take measurements and see if other cars have something similar.
Last Edit: Jul 30, 2022 12:32:34 GMT by ems1
1985 Manta GT/E 16v 2001 VW T4 Caravelle
Jul 30, 2022 13:54:54 GMT
If you can stick it together I'd be inclined to make a fibreglass mold and make a copy using fibreglass.
Jul 30, 2022 13:56:18 GMT
You must be able to get one sent over from the states.
Jul 30, 2022 15:20:42 GMT
Doesen't took too difficult to draw in cad and get 3D printed. (You could get the remains scanned and add the missing parts back in)
Jul 30, 2022 15:29:25 GMT
Cocktail shakers are great for chopping up to make column shrouds when you’re adapting bits together. One of the few things that have that gentle taper. Plus they’re stainless and more or less every charity shop seems to have em for a quid.
jgtr
Jul 30, 2022 17:43:49 GMT
Beer can😝
jpsmit
Jul 30, 2022 18:22:13 GMT
I think a 750ml or 1 litre perrier bottle has just about the perfect curve
Jul 30, 2022 18:51:14 GMT
Last Edit: Aug 3, 2022 16:02:56 GMT by HARDCORE
Jul 30, 2022 18:54:47 GMT
Last Edit: Aug 3, 2022 16:03:05 GMT by HARDCORE
Jul 30, 2022 19:06:28 GMT
Do you still have all the parts of your broken one? Its probably potmetal, so it cant be welded. But I think I'd give it a try with JB weld... Build up some thickness on the inside for strength, if you have space for it. Its amazing stuff, and I've had some good results with it..
Jul 30, 2022 21:18:33 GMT
I'd model it up and 3d print one if it's viable, depends what it holds.
Paul Y
Jul 31, 2022 10:23:19 GMT
metalshapes unfortunately the collar was already broken with a piece missing, it had previously been repaired which is why it was stuck to the column. Have to admit I was not in the best of moods when I was taking it apart so there was the distinct possibility of brute force being the deciding factor here…. Good shout on the cocktail shaker, will venture into town today and see what is available. In a quick update it looks as if a replacement might have been sourced from a comment on the truck forum and also from grizz reaching out to his network. Thanks all! P.
Jul 31, 2022 11:24:38 GMT
I think a 750ml or 1 litre perrier bottle has just about the perfect curve Exactly what I was thinking. There must be a drinks bottle out there that'll do the job
vulgalour
Club RR Member Number: 146
Coffee flask or travel mug might give you a decent stainless donor, they're cheap and readily available in a variety of similar shapes.
60six
Get hold of one of these www.ebay.co.uk/itm/363210994641measure width of both fitted ends then get an exhaust reducer made - it will be stepped though but will do the job. Get a stainless one and polish it up!
