Oct 25, 2022 10:06:33 GMT
Morning all. Found amongst my late grandads stuff. I've absolutely no idea what this is, and so far neither has anyone else who's seen it Teaspoon for scale, it's approximately 12cm x 12cm, solid brass, fairly heavy and extremely well made. There's zero backlash on the vertical movement, and very little on the horizontal. I'm thinking it's some kind of sighting measurement or adjustment, but even a tank museum who've seen it couldn't relate it to anything they knew. It's been suggested that it's aircraft, but I think it's too heavy. Bit of background - my grandad was an old-school engineer, and although he'd have had the skill to make this he wouldn't have had the equipment. He served in the engine room of a minesweeper off the east coast during the first world war, and head of maintenance for st.albans city hospital during the second. Anyone got any ideas? TIA Mods- please remove if you feel it's not relevant
jimi
Oct 25, 2022 10:55:17 GMT
Something to do with navigation (like a sextant) with bits missing ?
Oct 25, 2022 12:22:27 GMT
That my friend, is a German Broom Handle Mauser
Frankenhealey
Club RR Member Number: 15
Oct 25, 2022 12:39:23 GMT
It's a setting tool for something. Not much help I know
Oct 25, 2022 14:14:54 GMT
It's a setting tool for something, and there will be one person in the world who's got the something that doesn't quite work correctly as they can't set it properly
Frankenhealey
Oct 25, 2022 14:47:31 GMT
I've asked around and there is an idea it could be a fuse setter. Considering the method it's something that you would want to set only once but have the option to change. Considering your Grandfather's war service it could be for depth charges or mines. A naval museum or similar forum may lead to other ideas.
Frankenhealey
Oct 25, 2022 14:51:51 GMT
Someone has just contacted me to say that if it was WW1 or 2 it would be stamped with the broad arrow so probably not naval.
Oct 25, 2022 15:09:05 GMT
Thanks guys, all good info, unfortunately the guy who is looking for one will have to keep looking, it's not for sale
What units are the graduations/divisions? Metric? Or just ‘units’? Wondering if it is a profile measuring tool of some description or a setting tool ie do you put it in place first and then adjust, or set first and then put it in place?
braaap
Can You turn those two wheels a good amount to show in a new pic what parts move and how much so one can get an idea of the possible purpose?
Oct 30, 2022 17:03:45 GMT
Thanks for replying all Dorset_Clive, I put a tape measure next to it, units seem to be just that, but it must be quite old, even if its origins aren't war, I would expect it to be imperial, or degrees? braaap, pics of it extended, the vertical movement takes the'hook' with it, which has 2 holes in it, the vertical movement actually hits its adjustment wheel wound right back
Oct 30, 2022 17:15:43 GMT
Looking closely it looks like 10 units = 5mm…ie 2:1…I wonder if it is for measuring/setting a radius to give a diameter?
If you’re happy I could share around some ex-mil mates who might have a guess?
Oct 30, 2022 17:40:54 GMT
Share away Dorset_Clive, although as already said the Norfolk Tank Museum, and Frankenhealey's contacts didn't think so. Having said that, any ideas are welcome 👍
braaap
Oct 30, 2022 20:02:31 GMT
Thanks for the new pics, unfortunatley I still have no clue for its use.
