Nov 24, 2022 21:36:56 GMT
i am considering, either turboing my 1.1 metro or making it bigger cc but 8v. I tihnk standard in 8v 1.4 is the only other option to my 1.1
Now i have also the idea that i could fit a small turbo. The metro turbo on the A series didnt have an intercooler. Do you really need one for a small engine under 90 bhp? I want it to look as un obvious as possible.
What turbo is good for m application also please? Someone elese i know of has done it and used a citroen van diesel turbo.
thanks
Nov 24, 2022 22:23:14 GMT
Easy option might be the Renault 5 gt turbo setup. That's a 1.4L engine and you might even be able to use the carb of it.
You might get away with not using an intercooler if you run low boost but i would always advice to use one if there is room for it.
Nov 25, 2022 16:05:19 GMT
its on a single point injection system now, there is a lad on the metro forums who has done it already with this set up. He is using a standard ECU but turned up the fuel pressure, i have a speeduino ill use i think.
I think he said at 4psi he had 80 bhp which is more than enough for me, so no intercooler needed?
mfrv1
Nov 27, 2022 13:26:08 GMT
There is/was a company called Van Aaken Developments who did turbo kits for Fiat Cinquecento and Ford Ka, using Mondeo diesel turbos.
I have some scans of parts list etc somewhere.
Nov 27, 2022 23:22:15 GMT
Given the k-series is dimensionally identical from 1.1 to 1.8vvc is there a reason for not following that well trodden path other than “because…”? 🤣
What about a k turbo from a 75/ZT? Not sure about the fit as I only ever went from 8v to 16v 1.4 in my old rally car. Or for uber upgrade points how about a 2.5 v6 from a ZS? I know someone who’s swapped one into a ZR if that’s of any interest?
Nov 28, 2022 18:41:40 GMT
well, the main thing is its in the car now. So i know its good and not a headache before i turn the key. There is a quite a lot of 1.4 16v for sale, but i don't know how easy they are to fit. Also i think a small turbo 8v engine will give more torque than a 1.4 16v, probably something like the 1.8 though?
But the thing is, i like the idea of a metro turbo like the old ones where.
Any idea what turbo i should use?
I have speeduino ecu, and i am quite familure with wiring this stuff already as i have a rally car with a b230 volvo engine on microsquirt.
thanks
