Mar 31, 2023 12:51:07 GMT
on offer at the moment (2 packs for £20) looks like I could cover the whole garage for just eighty quid which seems to be way cheaper than any other options I've seen that must mean these are actually no good right? can't take the weight of a car, don't stay locked together, trap moisture underneath, tear easily, can't withstand spillages, make little puppies cry... this would probably be an interim measure to improve on bare concrete for a few years until I get round to doing a more expensive permanent job in the future help me oh wise retroriders - is this a false economy? halfords-6pc-black-floor-mat-set---120cm-x-180cm
Mar 31, 2023 15:17:27 GMT
I'll have to let you know as I have done the same. Apparently it's a good idea to leave 10mm or so at the edge as they expand in hot weather.
My garage floor is ridged concrete, but I rent so can't re-do it...
Mar 31, 2023 23:35:44 GMT
I have these, but I don't use the garage for the car. Been down a year or so, no issues with any spills or grinder sparks.
Made a huge difference to the cold floor!
I'm storing my sisters washing machine atm, I moved them for that. I also lift them for my swing-out rolling bandsaw trolley...
jonomisfit
Club RR Member Number: 49
Halfords floor mat sets?jonomisfit
@jonomisfit
Club Retro Rides Member 49
I use them dotted about the place where I stand for long times, like at workbench. The cushion effect makes it better.
I don't used them under the car as they are too soft and crush/ take a set under weights.
I've got them in my garage, my vespa scooter sits on them and it leaves indentations from the stand feet and tyres so I'd say not good for parking a car on
mashed
I've had some of these for about three years under a hot tub. They squish a bit over time but at £20 just buy an extra pack when they get damaged. They do them in black at B&Q as well
sounds like it might be a good thing for round the edges of the garage and I should get something stronger for where the car sits
it does mean I'd not need to buy so much of the sturdy stuff so could still be a fair money saver!
cheers guys
nigxl
Apr 11, 2023 18:24:23 GMT
on offer at the moment (2 packs for £20) looks like I could cover the whole garage for just eighty quid which seems to be way cheaper than any other options I've seen that must mean these are actually no good right? can't take the weight of a car, don't stay locked together, trap moisture underneath, tear easily, can't withstand spillages, make little puppies cry... this would probably be an interim measure to improve on bare concrete for a few years until I get round to doing a more expensive permanent job in the future help me oh wise retroriders - is this a false economy? halfords-6pc-black-floor-mat-set---120cm-x-180cmThanks for the heads up. Just ordered enough to do upstairs in the garage. It's got a wooden floor anyway but I thought why not get a softer feel. I'll put some pics up when they are down.
LowStandards
Apr 14, 2023 14:05:06 GMT
I have these around my workbench, probably around 6 foot into my garage. The car doesn't get parked on them, but it's amazing the difference they make walking on cold concrete or just kneeling down. 7 years so far. Don't get me wrong, they're pretty knackered now, mainly grinder marks and full of welding spatter and hot offcuts of metal. Kneeling is not so much fun now actually 7 years of welding, grinding etc
Apr 17, 2023 20:41:49 GMT
cheers for the link just bought some for my daughters shed / hang out / den
Apr 18, 2023 19:38:58 GMT
Before and after shots. These are hugely comfortable compared with the ridged concrete floor. Really easy to fit too - they cut easily with a Stanley knife should you need to fit them round odd bits in the garage. I haven't done much as yet but they look and feel good so far.
Apr 24, 2023 15:01:24 GMT
stuck down or just laid straight on top?
Apr 24, 2023 18:22:01 GMT
stuck down or just laid straight on top? Don't need sticking down, and apparently, depending on how much sun your garage gets, they can warp as they expand if they're glued down or right up to the walls Not had that issue with mine, but then my door faces away from the sun and I have a house at the back of the garage
fogey
Think I'd be a little concerned about grinding or welding on them . . .
Think I'd be a little concerned about grinding or welding on them . . . I don't weld, but I do use a grinder. No issues so far. However, any grinding I do is at the bench, might be different if you were under a car?
Halfords floor mat sets?ChasR
@chasr
Club Retro Rides Member 170
May 23, 2023 21:17:22 GMT
I have some of these.
For what they are, they do the job, but they do get dented easily.
