May 11, 2023 18:22:06 GMT
I have just got my car back on the road and am trying to check/tune the bike carbs. It has a set of Mikunis from a 1989 Yamaha FZR 600. I was messing around with the carbs and got what I thought was a reaasonable setting so threw a new set of plugs in it and did 10 miles of mixed driving. Before putting the new plugs in I leaned out the pilot circuit a bit as I think a sooty ring can mean a rich idle. Anyway, here are the plugs I pulled And these are the new plugs after about 10 miles of mixed driving I think it still looks a bit sooty around the edge (rich pilot?) and either OK or a bit lean on the ceramic and electrodes. Any thoughts or comments? Thanks
May 11, 2023 19:53:06 GMT
If it were a rich idle you would likely smell the petrol if was it burning that much fuel.
Are the carbs mounted at a similar angle to when in a bike and are the float heights correct and the float valves moving freely.
May 11, 2023 20:14:53 GMT
Yes, carbs are mounted pretty much at the same angle they are in the bike they came from. I think the floats might be a touch low, as when I go round tight left handers the engine stumbles - In theory, a left hand turn would slosh the fuel such that the floats would close momenterily. However, I have drained a float bowl and plenty of fuel came out. I think I am going to adust the floats to close later and see if that helps.
Last Edit: May 11, 2023 20:15:13 GMT by lewist123
goldnrust
West Midlands
Minimalist
May 11, 2023 22:09:29 GMT
Are you sure that’s the same angle as in the bike?
Commonly the join between the float bowl and the carb is horizontal, yours looks relatively steeply angled down towards the engine?
May 11, 2023 22:50:21 GMT
Definately - Infact, the wide angle of the pictures makes them look 'flatter' than they really are. I would estimate something aproaching 70 degress. In the bike the engine is canted forwards and they come up from the back of the head at a really steep angle and point up to the bottom of the fuel tank. I have looked at pictures. In addition, when looking at the jets sticking down into the float boal, at this angle they are basically vertical and pointing straight down into the bottom of the float bowl - here is a pic of them partially stripped. A bit ticky to see, but you can certainly spot the angle of the jets VS the outer surround of the float bowl. Edited to add - I would love it if they could be run at a lower angle as it would make air filters easier. I plan to pull the float bowls off to adjust the floats, and I will double check that the jets at pointing down verticaly when I do.
Last Edit: May 11, 2023 23:03:22 GMT by lewist123
slater
Club RR Member Number: 78
The plug looks OK. It will always be sooty on the main body as it never gets hot enough to burn off the carbon. It's the electrodes that matter.
That said it's really not possible to tune in a set of carbs properly by looking at the plugs. AFR gauges are so cheap nowadays just get one and do it properly!
I was going to say, I'd get the following to improve your chances of tuning it up
-IR temp gauge, to read the exhaust manifold branch temps, so as to see which one is fuelling more than the others -AFR gauge, so you can tune it right, and alot closer to the ballpark.
