Jun 20, 2023 10:32:08 GMT
Bit of an odd one but got a set of wheels (13” slot mags) that I thought were ford American fitting but are not it seems - they are 5x108 / 5x4.25 fitting … apart from Volvos .. what the bigger else do they fit and is there a demand for such a odd stud pattern ?
Thanks in advance
gezzard
Club RR Member Number: 69
Jun 20, 2023 11:08:19 GMT
some fairly modern french stuff is 5x108, not sure there's a demand for slotmags on a 3008 or C3 though!
Last Edit: Jun 20, 2023 11:09:17 GMT by gezzard
Jun 20, 2023 11:44:44 GMT
Some 60s/70s small mopar is also that pattern. Probably not small enough to need 13s though.
Stiff
'kin 'ell
Jun 20, 2023 19:06:23 GMT
Depending on the centre bore and et, there's a fair few. Obviously if the centre bore is on the larger end of the scale, they could be shimmed up.
Jun 22, 2023 11:04:09 GMT
Ferrari?
Jun 27, 2023 21:49:32 GMT
Indeed. IIRC, 308s had 14" wheels, as did earlier Volvo 240s. Not aware of anything 5x108 that used 13" wheels though.
