Aug 19, 2023 17:57:15 GMT
The 7"x5" headlights in my daihatsu are rusted & all the reflective is degraded so I've been told will fail an mot. I've looked online & replacements are rubbish but off road led ones are a lot better quality but are they mot legal?
Last Edit: Aug 19, 2023 17:58:04 GMT by ianlea73
mk2cossie
Club RR Member Number: 77
Led headlights mk2cossie
@mk2cossie
Club Retro Rides Member 77
Aug 19, 2023 20:09:45 GMT
The ones pictured, no. Mot fail, and not really legal. Mainly because they are designed for H4 halogen bulbs, and the LEDs pictured are usually way off for beam pattern.
Is there any fully encased units? Which just have the connections on the rear to join up? Those are fine for MOT, as the unit is designed from the start with a LED light source 👌
Aug 20, 2023 11:18:57 GMT
Would lights with projector beams rather than reflectors be legal?
Club RR Member Number: 160
Led headlights Rich
@foxmcintyre
Club Retro Rides Member 160
Aug 20, 2023 12:05:41 GMT
Would lights with projector beams rather than reflectors be legal? Yes. They are fine as they are a conversion unit rather than the wrong light source in a halogen lens. obviously pending what the beam pattern is obviously.
Aug 20, 2023 15:20:25 GMT
Rough Trax carry non LED ones for £20 a side if you would rather stick with incandescent bulbs.
Aug 20, 2023 15:32:30 GMT
I retail motorcycle parts for a living. In my experience so far, all the cheap ones are absolutely rubbish & the good ones are a ton of money. So much so that I have not even gone there yet on the retail side, as I won’t sell curse word & the good ones are so expensive, no one seems to want to pay it. They will come down & improve, then I’ll go there
79cord
Aug 21, 2023 10:58:12 GMT
The H4 sized projector lensed style globes look very interesting, often only using the original headlight reflector for a supplimental, less focused high beam function. If low-beam is up to standard!?
Unfortunately my car has early projector lens headlights so neither those nor LED replacement globes would seem appropriate & 2.5" LED projector units not so cheap, & dismantling of headlamps to fit too. Premium old Halogen globes not cheap either though. Probably do it one day anyway to add high beam function to those lamps though.
