Aug 22, 2023 19:46:34 GMT
cant seam to figure this out, temp gauge reads really high from cold and very soon after starting goes fully up tried a new sender = same tried spare cluster= same tested wiring 12v, ground and sender wire all have continuity and insulated from each other
BUT, if i test the cluster out of the car on the bench with only the temp connected it reads fine?
Last Edit: Aug 22, 2023 19:47:01 GMT by stevey123
87 manta redtop quantum 2+2 1973 mini xe'd mk4 astra van
Maybe replace the sensor and change the coolant see what happens?
Aug 23, 2023 15:39:28 GMT
new or old sensor does the same , coolant already changed, reads high when car is stone cold wondered if alternator rectifier issue would cause glitches?
Aug 23, 2023 16:50:52 GMT
Hi, It sounds like it's picking up an earth between the gauge and the sender, so look for damage to the loom or evidence of melted insulation on its route from gauge to sender.
Colin
Aug 23, 2023 19:59:50 GMT
thanks colin but i have run a new wire direct from sender to gauge with the same result
jimi
Aug 23, 2023 21:04:30 GMT
Sounds like it might be the wrong sensor for the gauge. What happens to the gauge if you disconnect the sensor ?
Have you got a set of gauges or a different water temp gauge you could try?
gauge reads zero when disconnected from sensor, tried a spare gauge but the same , can only think both gauges are faulty? but why would they work when off the car?
jimi
What happens to the gauge if you disconnect the wire at the sensor ? If it goes to zero, try earthing the wire and see what the gauge does
disconnected it goes to zero, earthed it goes full
jimi
That would indicate the gauge and wiring are ok and your problem is the sensor
Sept 4, 2023 10:13:12 GMT
yes ive bought another new sensor so fingers crossed!
