1971 heerey gtm cat 2 historic road/rally car
Correctly registered as a gtm
7.5 cooper s brakes
Full built in msa cage built into chassis with door/dash/roof bars
Foam filled sills with inter grated
1310 a series,21253 high compression pistons,block correctly decked
Competition bearings
286 cam duplex timing gear
12g940 big valve 11 stud head hardened seats
1075cr forged rocker gear
Twin hs4 carbs set up too run on unleaded
Lightened flywheel,orange cover,metro turbo plate all machined/set up correctly
Fully balanced
Custom distributor curve,electronic ignition,high output coil
Works spec high speed stater
Vw polo front rad,electric pump
A series close ratio straight cut gear box
Completion layshaft
3.4xpin diff
Completion oil pick up pipe
Custom quick shift gear change
FIA cut out switch,fully fused:relayed
Electric front/rear fans
Heated front screen
Integrated Piaa spotlights
Wired for navigator,map light,potti wiring
Foot rest with foot operated plotting/Marshall light
Fly off handbrake
£5500
Cheshire
7.5 cooper s brakes
Fully balanced
Completion layshaft
3.4xpin diff
Heated front screen
Fly off handbrake
£5500
Cheshire
