Oct 15, 2023 15:44:39 GMT
Said to be Renault Safrane 15” wheels. 4x100 in size. I know nothing more, did a Google to see if any Safrane came up wearing these……. NOTHING. Anyone got more information??
Last Edit: Oct 15, 2023 15:44:58 GMT by grizz
Oct 15, 2023 17:41:41 GMT
Hi Grizz.
Google lens has them as Elysée' 15 inch alloy wheels for a Renault Safrane.
Oct 15, 2023 18:07:34 GMT
Thank you vulgalour and tubthumper Now to figure if they will fit early VW Golf’s and Polos They seem quite flat, rather than the usual steelies etc.
vulgalour
Club RR Member Number: 146
Anyone recognise these wheels?? vulgalour
@vulgalour
Club Retro Rides Member 146
Oct 15, 2023 19:31:54 GMT
I wanted to put some Renault wheels on my Mk2 Polo years ago and I have a vague memory I couldn't because the Renault had a smaller centre bore and I didn't want to get them machined. I might have remembered wrongly. Wouldn't hurt to check that anyway.
Oct 15, 2023 19:33:13 GMT
I wanted to put some Renault wheels on my Mk2 Polo years ago and I have a vague memory I couldn't because the Renault had a smaller centre bore and I didn't want to get them machined. I might have remembered wrongly. Wouldn't hurt to check that anyway. Possibly why no Golf Mk2’s run them.
Oct 15, 2023 22:27:30 GMT
I wanted to put some Renault wheels on my Mk2 Polo years ago and I have a vague memory I couldn't because the Renault had a smaller centre bore and I didn't want to get them machined. I might have remembered wrongly. Wouldn't hurt to check that anyway. This is correct. I put a set of Renault wheels on my Mk2 Golf about 10 years ago. I used a dremel to open up the centre bore (oh to be young and stupid again..)
Oct 16, 2023 10:32:42 GMT
I guess it is one of those, despite the look and liking the idea of making them two/three tone that having to “engineer” them to get it right, precludes any further thoughts about them.
Sadly.
Oct 16, 2023 11:29:59 GMT
I wanted to put some Renault wheels on my Mk2 Polo years ago and I have a vague memory I couldn't because the Renault had a smaller centre bore and I didn't want to get them machined. I might have remembered wrongly. Wouldn't hurt to check that anyway. Possibly why no Golf Mk2’s run them. There's an even simpler reason: when was the last time you saw a Safrane? Have you ever seen a Safrane? I have, and it wouldn't start. Ever again, because the timing belt was broken.
Oct 16, 2023 11:42:54 GMT
Possibly why no Golf Mk2’s run them. There's an even simpler reason: when was the last time you saw a Safrane? Have you ever seen a Safrane? I have, and it wouldn't start. Ever again, because the timing belt was broken. Good to see you are alive Nick.
Oct 16, 2023 14:31:09 GMT
Oct 16, 2023 17:08:19 GMT
So, as a non wheels type guy, not ever able to differentiate between PCD, Offset and Lug Nuts vs Lug Bolts (Joking on the nuts and bolts)
Are these compatible with rings?
VW
Center Bore / Hub Bore: 57.1 mm Bolt Pattern (PCD): 4x100 Wheel Fasteners: Lug bolts Thread Size: M12 x 1.5 Wheel Tightening Torque: unknown TIRE RIM OFFSET RANGE mm Tire Pressure (front / rear) bar OE 185/60R14 82T 6Jx14 ET38 36 - 40 2.1
Renault
Center Bore / Hub Bore: 60.1 mm Bolt Pattern (PCD): 4x100 Wheel Fasteners: Lug bolts Thread Size: M12 x 1.5 Wheel Tightening Torque: 90 Nm TIRE RIM OFFSET RANGE mm Tire Pressure (front / rear) bar OE 185/80R14 91S 5.5Jx14 ET50 48 - 52 2.5 2.3
Oct 16, 2023 20:30:36 GMT
Someone will probably shoot me down but if those are the dimensions from the vw/Renault then don't you just need these Cheap spigot rings from the bay www.ebay.co.uk/itm/151342046032
Someone will probably shoot me down but if those are the dimensions from the vw/Renault then don't you just need these Cheap spigot rings from the bay www.ebay.co.uk/itm/151342046032No shooting here. Someone mentioned that as an option. Thanks for the posting as well.
adam73bgt
Club RR Member Number: 58
Oct 17, 2023 11:30:53 GMT
So, as a non wheels type guy, not ever able to differentiate between PCD, Offset and Lug Nuts vs Lug Bolts (Joking on the nuts and bolts) Are these compatible with rings? VW Center Bore / Hub Bore: 57.1 mm Bolt Pattern (PCD): 4x100 Wheel Fasteners: Lug bolts Thread Size: M12 x 1.5 Wheel Tightening Torque: unknown TIRE RIM OFFSET RANGE mm Tire Pressure (front / rear) bar OE 185/60R14 82T 6Jx14 ET38 36 - 40 2.1 Renault Center Bore / Hub Bore: 60.1 mm Bolt Pattern (PCD): 4x100 Wheel Fasteners: Lug bolts Thread Size: M12 x 1.5 Wheel Tightening Torque: 90 Nm TIRE RIM OFFSET RANGE mm Tire Pressure (front / rear) bar OE 185/80R14 91S 5.5Jx14 ET50 48 - 52 2.5 2.3 Going off those numbers, the Safrane wheels are higher offset than the standard Golf wheels so the wheel will sit further inset in the wheel arch, so watch for clearance to brake calipers etc. Could be spaced back out if it posed an issue
Oct 17, 2023 11:40:39 GMT
