I've got my hands on a gearbox to manual swap my Honda Civic EJ9 D14, but I need a few more bits. Would anyone have any of these bits, most of them can be from any EJ/EK manual unless otherwise stated:
If anyone has any of that lot then please get in touch.
Thanks!
- Clutch pedal
- Clutch master cylinder + reservoir with little metal bracket
- Pressure plate to flywheel bolts x6
- Gearbox torque bracket + bolts (the lower steel one on the end of the 'box, that connects to a mount under the chassis leg, from a D-series engine only).
- Gear shifter + plastic surround + linkage arms (linkages from D-series engine only)
- Manual starter motor + the two securing bolts
Thanks!
